Fixing hole in side of block
joesmith123
L295DT, BX1500
Mar 18, 2023
450
68
earth
Back on the hinge while waiting for parts
Mixed acetone with trans fluid, apply with brush, hit hinge with torch
If chinese gaskets make it: make progress on engine
Still don't know why both starters are doing the same manner like the video posted earlier
If everything is lubed, try this. Connect the (-) cable to the block or starter mounting bolt, then touch the (+) to the stud on top with the braided wire going to it, that should bump your starter. Forget about the signal wire for this test.
This statement could be on to something
"Braided wire going to it" is ground, correct?
In my head, this is connecting positive and negative and causing a short
Or am I incorrect?
Summary: work on hinge, figure out why both starters won't spin, and get gaskets to continue reassembly of block
Woah look at this: chinese gasket kit for $100, ordered on Monday from China, got here today (Thursday)
Now: forgot about the hinge, get back to engine assembly
Installed oil pump: put gasket on, got it into proper place, put in long bolts,then short bolts, then looked at diagram, put in the small key, then placed gear with protruding end facing front of tractor
Put gears and their hardware on not too tight in case I make mistake
Starter problem solved by @kutobaguy007, ground wire on engine block not on starter
Video: engine spin fine, that gives go ahead to keep rebuilding...
Rubber mallet pushing fuel gear into its place
Got gears in with matching numbers
But forgot the bolt keepers
Take gears out, get in the bolt keepers, tighten bolts, put gears back in properly with matching numbers
Took idle gear back out, put in bolt keepers for both idle and camshaft gears, using chisel to lock bolts in
About to hammer in crank gear using 2 inch pvc
I Installed the oil pump gear facing right way, correct?
I point: 1 mark on crank gear
Now: twist crankshaft to make 1 point up, then put in idle gear making all 3 marks match
Got the markings to match, look closely you can see them
007kubotaguy
B7100DT L245DT JD 2355
Dec 23, 2012
613
220
Herald Calif.
Positive battery cable goes to the large lug next to the trigger wire. The ground cable goes to the engine block not the starter. You have the ground lead going to the stud that takes power from the solenoid to the starter motor.
6869704x4
L45TLB, 49 8N, 57 641, RTV-X1120D, Z422
Jun 29, 2011
274
319
SE, NM
Put the ground to starter body for bench test.
Good starter description
joesmith123
L295DT, BX1500
Mar 18, 2023
450
68
earth
Setup of how I matched gears
Put clamp on crank, rotated to match 1 marking with idle gear, then adjusted marking 2 and 3 gears by hand, then hit idle gear with mallet pushing it into rest of gears
Now: finish up rest of hardware, hand spin it, then spin it with starter
Up close of hardware in front of crank gear
Gear - small collar - big flat ring - small rubber seal - big thick collar - oil seal
Do I have them right?
Pushed them in
Put in the locking rings, hit oil pump bolt with compressed air impact, hammered on bolt keeper
Top right ring, camshaft, is a bit loose, tried tightening it,
the top left gear, fuel camshaft, has the same ring on both sides?
How I installed this area: first long collar, gear protruding toward back of tractor, then locking ring, same ring as front gear
Hit everything with compressed air, soaked all bearing areas and gears with diesel, spun by hand, spins fine, now spin it with starter
Spins ok with starter
Continue reassembly, retrace your steps, figure out governor
Organized hardware for next section: look at diagrams, figure out where everything goes
Mightve put hydraulic gear backward
In this image, they have collar - gear protrusion facing FRONT of tractor - lock spring
My install: collar - gear protrusion facing rear of tractor - lock spring
I copied videos I had before disassembly, but diagram says otherwise
Photo of disassembly, protrusion of gear facing rear of tractor
Workerbee
Zd21
Mar 1, 2020
179
64
MN
Is there a timing mark on that gear? If so the gear would need to be installed to the side you can see that. If not, Id think your original video from disassembly would be correct.
4,864
View attachment 137489 View attachment 137489
Pushed them in
Trial and error reassembly?
What could possibly go wrong?
4,665
'learn by doing', NOTHING wrong with that.
I still give Joe A+++ for tackling the job that many here wouldn't !!!
Yes, it might take another 6-10 pages of posts to get to the video of 'It's ALIVE' but he's 'turning wrenches' !!
Reactions: 6 users
joesmith123
L295DT, BX1500
Mar 18, 2023
450
68
earth
No timing mark on that gear
Interesting, you would follow how it was assembled even if it is different than diagram
Later on: I can further disassemble that component and see how the gears line up both ways
That last picture in last post: from August 17 when I was disassembling the area: clearly gear facing front of engine
Parts showed up for other engine: main bearings include thrust, 3 seals to seal up crankshaft assembly, gearcase gasket
Notice this main seal matches the size of the original
Hydraulic gear problem solved
I try to show you in these two pictures, that the gear it connects to is further to the front of block, and the hole inside that component is deep
Meaning, @Workerbee is 100% correct, that i assembled it properly, and that the diagram can be wrong
Putting on hydraulics, looked around diagram, matched all bolts and washers
Cleaning sealing area with piks, files, compressed air, diesel
Installed hydraulic filter using proper hardware per diagram
Stuck now on governor spring, look back at pictures, look up close on videos, try to see how they install the spring
I study this diagram and look at old videos to figure out spring situation
Looked up the springs: 140 is tiny spring, 150 bigger spring
Brought gearcase and other throttle parts to try to understand the assembly
I wish they show how the little spring goes (140), bigger spring I might understand it
Spring 140: trying to properly install it
jaxs
B1750HST
Jun 22, 2023
656
412
But rather than cheer from the sideline don't you think there's more to be learned by tearing an engine down and following along? Authentic gesture of solidarity with Joe is worth more than words could ever be. I'm behind Joe all the way and if I were physically capable I'd be right up there beside him instead. I know,I know you're thinking I'm making up excuses for not doing as I say do but let me explain. I have a neighbor who is amongst the best of motivators came to me in some of my darkest hours. Once when I had lost all hope he showed me a light at the end of the tunnel. I was so elated I rushed to meet it. Unfortunately it was a freight train. I still had hope and one day I felt another man had treated me unfairly. My neighbor persuaded me to withhold judgement until I had walked a mile in his moccasins. I was bite numerus times by his moccasins on that mile walk,almost died and never fully recovered.
Undeterred I vowed to plow up turf in my yard to allow full appreciation for Joe's floor but my wife threatened me if I followed through. She said if I messed our yard up she would divorce me and have her dad revoke the trust he set up that allows our lavish lifestyle. Big hats and new trucks mean less than dedication to friends but squandering life with a woman 40 years younger than me is too much to bear.
joesmith123
L295DT, BX1500
Mar 18, 2023
450
68
earth
Is the smaller spring right?
I knew I should have taken more closeups before disassembly
I try to follow the diagram where it goes from one to the other,
I'll keep tinkering with it once I get back to the shop
Oh I see, they want that smaller spring on the front hook, not the back hook
In the picture, that spring is in the wrong area, it needs to be up front
0 chance I can figure it out without these diagrams
I am using that little line next to 140 to understand the way they want it
Video of how I have it: watch it closely and critique it
I have since curved in the ends to make it hold better
In the meantime I let it marinate and get more parts ready for reassembly
Realized I can go on with the gearcase reassembly
Pushed in collar with pvc, then pushed in key with back of chisel
Taking off gearcase oil seal: spray diesel, torch the area lightly, push out using back of chisel
Took out seal, hit lightly with round file, wipe down
Pushed in chinese seal, smack flat piece of flat steel with sledgehammer to push down evenly
Wet sanding bumps in liner with 1000 grit, spray diesel
Gave entire block and gearcase hard hits with compressed air, then part cleaner
Linear lines on all 3 liners
Before closing engine, hitting everything hard with cleaners to get rid of all whatever
Hit also crank and oil pan area pointing upward
4,665
re: But rather than cheer from the sideline don't you think there's more to be learned by tearing an engine down and following along?
BTDT.. 100s of gas engines...from COX049s to BBV8s, though no diesels, well, 1... for an RC Airplane I once built.
I also have designed/built a LOT of electronics from crystal radios to optical emission spectrometer data acquistions computers to remote controlled energy management systems, hand soldering everything or wire wrapping.
Current project is to make a towable, small scale rotary soil trommel. something the BX23S can tow, then use tractor to load the hopper. While not as 'complicated' as an engine rebuild ,it's more challenging.
2,760
I’m not sure I understand what you meant to convey completely, but I think I do agree with it… Thanks for sharing.
Also agree with GreensvilleJay perspective as well…
joesmith123
L295DT, BX1500
Mar 18, 2023
450
68
earth
Installed gearcase
Put grease on o rings, stuck them on gearcase
Didn't forget about o ring on water pipe
Put grease on edge of gearcase, stuck gasket on it
Placed gasket in position, went and made sure o rings didn't move, smack gasket into block
Now: look at diagrams, organize hardware, fasten gasket to engine
Looked at diagram, figured out bolts to secure gear case
Put rest of parts on, cut scrap paper and tape areas that don't need paint
Put thick coat of paint
dragfan66
B7500 Z231KW G1800 L3350DT
Apr 12, 2020
41
29
Alabama
One thing for sure, Joe's play by play documentary and photography are spot on.
Virtually all pictures are crystal clear.
5,156
Joe, is your operation taking place in a sand blasting area, desert, or what? I always see the sand in the background.
