Sat on my M6800S and cried, just replaced my cab a/c, then had to replace Hyd pump, now clutch is hard to press down, dont know what to do now!!
Big help but I would go another step longer, that would assure that you gain the last bit of strength and leave a margin of safety should a bolt begin to loosen. Bolts can be bought at numerous places and perhaps for a lower price, just be sure they are the same grade.What I really like about this site is all the knowledge and if someone sees something wrong in your post, they respectfully let you know (well maybe @SidecarFlip was an exception).
Thanks @lynnmor for questioning the bolt length in post 19,502. I got ahold of parts schematic and used sharpie to trace the bolt. Bingo - been ordering the wrong bolt for 2-years. Since I hadn’t removed 2 of the bolts it looks like whoever installed the subframe used the wrong side bolts for that piece too. There is a L and R and they are different lengths.
Here’s before and after. This explains why I was stripping bolts, not enough bolt into the nut when torquing to specs.
Thanks to everyone that commented and kept my brain thinking.
Just goes to show that sometimes it ain’t the length of the bolt, but maybe it’s if the bolt is in the right place.What I really like about this site is all the knowledge and if someone sees something wrong in your post, they respectfully let you know (well maybe @SidecarFlip was an exception).
I like the way you think!Just goes to show that sometimes it ain’t the length of the bolt, but maybe it’s if the bolt is in the right place.
