Gus1957
M6800, L2501 TLB, BX2370
Dec 17, 2023
42
35
Cobleskill NY
Used L2501 Hoe to lift rototiller back on M6800 after modified lower arm slip hitch slid off.
This 5'Kuhn rototiller is a bear from the 80's, but it was sized for a 35hp tractor. Had to modify the lower attach points so it would sit lower in the ground on the M6800. Plowed ground 1st and picked lots of rocks but never get them all. With tailgate up on rototiller bouncing a lot which made the lower arm point come off. Handy having 2 Kubotas.
Reactions: 8 users
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
869
canada
It always amazes me why the rocks never end. You can have a 200 year old field that still has rocks in it. You would think at some point the frost would run out of rocks to push to the surface.
Gus1957
Dec 17, 2023
42
35
Cobleskill NY
We bought this property 34 years ago and it was in hay. We were told it had been in corn like the next 3 fields next to us. We rotated hay and pasture on it for 25 years. Now a neighbor is cutting the hay.
I wanted to improve some areas and eventually restore ground to level over sunken drain tile lines.
So this was trial work. I couldn't borrow discs from anyone.
I borrowed IH 3 bottom 12" plows which worked well with the M6800 and they went down 8-10".
I wonder how much rock was picked previously ?
lynnmor
B2601-1
May 3, 2021
1,637
1,414
Red Lion
I think that erosion plays a large part in rocks coming to the surface. For example; I have a stone fence around my property and the ground has risen to the top of the fence at the low point of the property despite no farming over the last 80+ years. On the opposite of the fence the farmed ground level is about six feet lower and the stone fence is being undermined. It is a slow process, but just look for those lone trees on a mound in the middle of a field and it will become clear what has happened.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,495
3,611
PEI Canada
Greased the loader, mowed 3 acres and my three times a week ritual of watering trees.
Reactions: 9 users
Old_Paint
Dec 5, 2020
1,898
2,050
AL
Today the Kubota played helper. My son operated it to pull up the 2nd section of my radio tower. I have a pulley / snatch block attached to my ballast box (laying on its side). The issue I had was as the section started to go up the ballast box would side toward the tractor. Then the pulley wasn't directly below the pulley on the gin pole. When that happened the aluminum gin pole started to bend - not a good thing.
Tried loading more weight on the box - some heavy block and and 25 gallon filled water tank. Still no love. Ended up driving an angle iron a foot into the ground against the box. That stopped it from moving. After that easy peasy!
The next 4 sections should be really easy
And to think we used to pull a section of RON-25 up with 2 people. I like your idea so that no one’s under the suspended load, but something’s wrong if you’re moving that much weight to pull a 60 pound section of tower up. Shouldn’t ge a bit heavier after it leaves the ground. I used a steel gin-pole though and the tower would flex more than the pole until the tower was tall enough for another set of guy wires. Normally I put them every 40 feet on anything under 100 feet tall, every 50 feet on 200 footers. But your solution with the stake is probably what I would have started with, driven into the ground in the opposite direction of the pull. Hard to beat a good‘deadman’ in the ground. For that matter, why not just use a strap around the bottom of the tower and shackle the snatch block to the strap? Whatever, job well done and no one hurt.
WAS BANNED FOR NSFW PICS
5,153
Cut the grass again. 197.9 hours on the clock. I just have 2.1 hours till I need to do the 200-hour service. I guess that tomorrow I will drive it up and down the road ticking off the tenths of hours till it stops at 200 hour mark.
5,149
Had several trees fall across the trails when Debby came through. This maple was the largest and most irritating as it was at the western most creek crossing. Obviously rotten at the bottom but was hanging on too tight to just pull it off the stump. Couldn’t tell exactly how much of it was rotten and how much was still solid so cutting on it was a little dicey. Whittled on the solid part (on the backside) and pulled. Whittled some more and pulled again. Wouldn’t budge. Eventually decided the risk/reward was no longer making sense so advised the only two others that might care to stay clear of it until it came down. Wife asked if I was planning to leave it there for the next two years until it rotted down. Told her I was planning to leave it there for the next two storms and if it hadn’t moved, I’d cut a couple of small trees nearby to get enough clearance to throw a rope up toward the top to see about breaking the limbs that had it hung but if we could avoid that, we would.
Came back the next day on the way to clear a couple other trees blocking trails and it looked like the below pic (minus the chain). It had fallen about half off the stump.
Irritatingly, it has a pretty descent sized poison ivy vine in it. Not much excited about processing it for firewood while that’s still fresh and sappy. I’m not severely allergic but not immune either.
A snatch block to double line pull successfully separated it from the stump. The chain is a Grade 70 3/8” that is always on the Farmi for stuff like this where the Farmi chokers are either too short (they were way short on this one) or it’s a snatch block pull where a higher capacity chain is preferable.
A reset for a single line pull inline with the tree pulled it out of the tree it was hung in and mostly out of the path. A little chainsaw work after it was on the ground got it into grapple sized pieces. Will probably go back to retrieve it for firewood this fall or winter when the poison ivy is mostly dried and the tree has lightened up a good bit. All but the very bottom was solid so there’s a good bit of useful wood there.
Before the winch, these type hung trees were a real pain to deal with. Although I’ve done it many times, I’ve never much liked taking them on with just a saw. Rigging up ropes and chains with snatch blocks, etc. to drawbar pull them is certainly viable but it takes a lot longer than setting up a winch pull. Between the grapple and winch I was able to clear this tree, one other single tree, and a cluster of one pine about the size of the maple plus about a half dozen smaller trees it took down with it in just over two hours. Back when the 9N was the only tractor we could get across the creek, that same work would have taken at least two days, a lot more sweat, and a lot more danger. Even if we could get the Farmall over there it wouldn’t be much better than the Ford. Sometimes it still feels like cheating working with the L.
Reactions: 10 users
jyoutz
Jan 14, 2019
3,426
2,509
Edgewood, New Mexico
It’s been a rainy summer monsoon season and the grass is high. I starting field mowing today.
Reactions: 8 users
afphinfan
Kubota L4300
Aug 9, 2024
12
Lake Martin, AL
Yesterday I acquired a heavy duty boom pole and a 3 pt dirt scoop for the new to me L4300. Of course I had to change the cat 2 draw pins and one was rusted on tight. Multiple PB treatments and a couple of big wrenches got it done but wore me out in this heat. Tested them out uick and put everything up for the day.
Gasifier
2014 Kubota L45 TLB, 2016 RTV X1140C, 2024 Land Pride RCF 2072
Came back the next day on the way to clear a couple other trees blocking trails and it looked like the below pic (minus the chain). It had fallen about half off the stump. View attachment 135189
Irritatingly, it has a pretty descent sized poison ivy vine in it. Not much excited about processing it for firewood while that’s still fresh and sappy. I’m not severely allergic but not immune either. View attachment 135190
A snatch block to double line pull successfully separated it from the stump. The chain is a Grade 70 3/8” that is always on the Farmi for stuff like this where the Farmi chokers are either too short (they were way short on this one) or it’s a snatch block pull where a higher capacity chain is preferable. View attachment 135191
Nice work NCL!
5,179
Of course you will!
The manual mandates an oil change at EXACTLY 200 hours?😄
S-G-R
Jun 17, 2020
1,495
3,611
PEI Canada
What kind of trees are you watering?
Most of them are spruce followed by maple and oak that i planted this spring. We've had a very dry spring and summer and I lost 36 spruce so far. Supposedly three days of rain in the forcast but their predictions haven't been accurate so I won't hold my breath.
retiree-urgency abandoned
B3350, Kub. 5" rotary cutter, LP 48" forks, Titan Aerial Platform, KK XB Dump
Dec 1, 2020
100
107
Bloomington, IN
I finally got some time to get my B2410 cleaned up and some maintenance done on it. Did the oil and filter change, as well as air and fuel and topped off the hydraulic fluid. Since my barn is full of hay it has been sitting outside and there is some nasty stuff floating around, the tractor looked like it was sitting outside for years instead of 2 months. Power washed it and looks good again. Just need to get a regulator for it and it will be back to full strength.
I had some leftover scraps of tint and applied it to one door and the windshield of my L4060 so now I no longer get blinded in late afternoon. The dealer finally replaced the EGR valve a few months ago, and has been trouble free since. I need to get the fields cut but I have no where to store the hay. My neighbor plans to buy it all, but is doing it small batches at a time, and in the mean time I lost 210 bales due to rain. Could not get it moved in time. So for now just letting the fields grown.
On your wet bales, if you haven't already done something with them, you might try selling them to EPA, state EPA or an environmental remediation company. We ended up with our share of wet round bales at the edge of the field and EPA bought them all for a creosote plant cleanup project.
Abandoned the hay business a few years later when we had a field full of square bales - when I called our neighbor ("I"ll take all of your square bales") to pick them up out of the field, she told me she bought a barnfull from someone else. Had to close our business for 3 days to put up the unclaimed hay - found a buyer to buy them at $5/bale - my cost worked out to $100/bale. Now I bushhog the fields once a year and the critters and pollenators have the run of them.
pokey1416
Jun 24, 2020
567
843
SW Michigan
What I really like about this site is all the knowledge and if someone sees something wrong in your post, they respectfully let you know (well maybe @SidecarFlip was an exception).
Thanks @lynnmor for questioning the bolt length in post 19,502. I got ahold of parts schematic and used sharpie to trace the bolt. Bingo - been ordering the wrong bolt for 2-years. Since I hadn’t removed 2 of the bolts it looks like whoever installed the subframe used the wrong side bolts for that piece too. There is a L and R and they are different lengths.
Here’s before and after. This explains why I was stripping bolts, not enough bolt into the nut when torquing to specs.
Thanks to everyone that commented and kept my brain thinking.
Reactions: 7 users
