Mitjam
Jan 14, 2013
Edmonton, Alberta, Canada
Such a great set up. Interesting how the outside tires look like the aircraft type and the inner four are laminated. I really enjoy pulling the folding cutter around and would sure love to have that tractor.
Thank you sir. Your spot on about the tires, the mower originally came with aircraft tires but after time the rubber wore out and foam started coming out and the tire started going out of round and wobbling. So I priced out tires 😢 $900 per tire cnd for the aircraft. Nope I bought laminated. If I go any distance I load it on the trailer anyways. The M6 is definitely a nice tractor. Too many buttons though I like my 108s for that haha
fc1
L3940
Apr 17, 2024
30
57
Nothing! Been working long days this week and it's really too wet to do much tractoring. I parked it outside my office window to look upon fondly instead, lol...
rc51stierhoff
2,568
It looks kinda lonely in that big yard all by itself looking back inside for some attention. It might a like a playmate. 🤔
matt-m
2022 B2601
Mar 17, 2022
60
323
53
Columbus, IN
The little B has been indispensable on the 'grill porch' project. Was excellent at carrying tools and materials up from the barn and then moving stones and gravel (for dog run).
What is a 'grill porch' you ask? It's a place to store grills & smokers outside (behind those sliding doors) to solve the first world problem of still wanting to do this when it's raining.
Reactions: 15 users
ctfjr
L3800HST
Dec 7, 2009
1,808
2,125
central ct
Had 21t of fill delivered and spread almost all of it.
The border of our lawn and woods is was fairly steep. That where any vehicles, including the tractor, travel to get to the back of the property. It was always a pucker moment when carrying anything heavy on the fel, no matter how low it was. I ordered a load of fill yesterday (2"-) and it was delivered this am.
Most was used to kind of level the path where vehicles travel and some was used to add mass around 2 of the I beams I just planted. I'll spread the yard or 2 that's left tomorrow. The material was just back bladed with the bucket. After another load is spread the box blade will be used to finish it. It has made a big difference already. With a heaped bucket I was wishing the ballast box I put together (~750lbs) weighed more!
Reactions: 7 users
jyoutz
Jan 14, 2019
2,697
1,775
Edgewood, New Mexico
My tractor is at the dealership getting 3 remotes and a top and tilt kit installed.
Reactions: 7 users
rc51stierhoff
2,568
Good day. That’s great. What pushed you over the edge on the TNT? I have remotes which is handy with my hydraulic back blade…but my back blade kind of a pain to hook up…I wonder TNT would help that (it sags so makes the QH20 not helpful). Anyways, just curious.
jyoutz
Jan 14, 2019
2,697
1,775
I have a 1025# Bison blade that does everything: angle, tilt, offset. It’s a bit of a brute to manually adjust. I wish that I could get 4 factory remotes because the blade has 3 adjustments plus the top link. I won’t need the tilt cylinder on the blade, since I’ll have it on the 3ph. I installed a manual ratchet link for the offset function on the blade, so I guess I’ll just install the angle cylinder on the blade. I’m hoping that I can just pull the pin on the angle cylinder to reverse the blade.
mcmxi
5,572
NW Montana
Nice! I wouldn't have a tractor without three rear remotes and top-n-tilt. If you have a Quick Hitch, top-n-tilt makes hooking up to compatible implements about as easy as anything can be.
jyoutz
Jan 14, 2019
2,697
1,775
I don’t have a quick hitch, but the extendable lift arms make attachment of implements pretty easy.
mcmxi
5,572
NW Montana
I took the M6060 and RC3712 out to my friend's place late yesterday afternoon and did 1-1/2 hours of cutting before he called me inside for dinner. I left the tractor at his place last night and will be back over there Sunday morning to finish.
The vegetation is fairly thick in places so I was running in mid range, 2nd gear at 2mph which works well.
Once I've made one pass over everything I'll run around again at "high speed" to get any areas that I missed. I'm still learning the technique of making turns without missing sections. One thing is for sure, no neck pain this morning since I rarely need to look over my shoulder running this thing.
Reactions: 9 users
S-G-R
LX3310
Jun 17, 2020
1,037
2,051
PEI Canada
What a beast!
Mitjam
Jan 14, 2013
I want a new landpride (orange) mower. Nice setup 👍
Mitjam
Jan 14, 2013
And also I heard the orange ones cut the best too haha
S-G-R
LX3310
Jun 17, 2020
1,037
2,051
PEI Canada
Gave a stump bucket a try. 4" stump took about 3 minutes to dig out. Not much of a workout but something different to try.
Reactions: 8 users
mcmxi
5,572
NW Montana
Thanks ... I almost ordered the Land Pride tan but thought better of it so changed my order to Kubota orange .... and thank goodness! 😂
4,471
Mowed and sprayed the tractor to clean it up a little.
Geddy helped.
Reactions: 11 users
