I noticed that the 3PH on the B6000 seems like it is pretty jacked up and seems to be missing the correct left and right vertical lift rods. You may want to move them from the older tractor.Got it home today!
Now to take off the loader and rototiller from the old one. I'll give them a quick coat of paint before putting them on the new one.
I'll also have to figure out how to Tee the rear hydraulic line and the loader lines together.
I'll also have to decide if I want to swap over the rebuilt injectors and new glow plugs from the old one as well. Same with swapping the OEM air intake over to it or not...
View attachment 128137 View attachment 128138 View attachment 128139 View attachment 128140 View attachment 128141 View attachment 128142
That is an interesting method to get the rear blade adjusted using a motor and chain drive instead of a cylinder to move the blade angle. Do you know why it was done that way?
