Zl1501 4x4
Rickybobby609
11
C.M.C.H. New Jersey. US
I just got a brush hog and was using it yesterday but whenever I tried shifting into gear when the pto was engaged it would grind but no grinding or anything and it shifts fine without the pto on any ideas?
5,167
Have you put an overrunning clutch on it?
If not then there is your issue, your PTO is driving the backside of the Transmission gears. ;)
Rickybobby609
11
I’m not sure what kind of clutch is in it I’m assuming whatever was in it from the factory I haven’t touched the clutch except to adjust the pedal when I first got it is there anyway I can tell what kind of clutch is in it?
Rickybobby609
11
Could I just get an overrun clutch to go on the end of the pto shaft and use that even if it does have an internal one? I just don’t want to have to pull this thing all apart but I need it working right for this weekend
