Raise the deck all the way, turn the knob to desired cutting height, and then lower deck. In order to turn that knob, the deck must be raised all the way. Once you find the correct height you want to mow, you need to adjust your anti scalp wheels so that you can slip your fingers between the bottom of the wheel, and the ground. Best to check that on concrete. They should not be riding on the ground all the time.
