I have a 2010 ZG227 Zero Turn mower. Zero issues until a few days ago. While mowing it died just as if it ran out of gas. After some troubleshooting determined not getting voltage current to the fuel pump. Checked the relays and all measurements were within the ranges listed in the service manual. Fuses checked out as good. The interesting part is when you unplug the heat sink voltage regulator the fuel pump electrical connection will read 12v and fuel pump will run as it should with key turned on. Issue with running it this way long term as I understand it... my battery will not charge.
Additionally, with a rigged-up gas tank gravity feeding the engine, it runs fine and with the voltage regulator connected the battery tests out as charging properly.
How can I determine if my voltage regulator is truly bad? What else should I consider as causing the problem of not getting 12V to the fuel pump with the key is turned on as it should? Any assistance is much appreciated.
