New to the forum and new to working on Kubotas. I did search the forum, but did not find much related to my mower...
I have a 2011 Z725 - 60" with a Kholer 25HP engine that usually starts and runs with what seems like about 1/3 throttle, though the throttle is at full. After a while, but very randomly, it accelerates to full RPM. it will then cycle every so often back and forth from that 1/3 RPM to full. Sometimes it will run for an hour at full RPM.
I have removed the belt and checked that each pulley turns freely and does not have significant play in the shaft bearings. I suspect there is a fuel delivery issue (or perhaps a linkage issue), of some type of electronic safety or cut off, but I'm quite confused because it doesn't stop the engine, it just goes to about 1/3 power. I doubt it is the inline filter, because occasionally it runs great. There is no obstruction in the mower deck. I have not investigated the tank other than to check that the manual fuel shutoff valve is fully open. I keep the tank quite full.
Thank you for any insight you may have.
