Hi Vic,
I have inherited a BZ7000 when purchasing a block on land.
Can I still buy parts for my BZ7000? Is there a Kubota equivalent?
I am trying to restore it to a fully functioning unit.
The engine works fine but the drive chain needs some work. Also a lot of the panels have rusted through in places.
The main problem at the moment is that the splines on the coupling on the main shaft joining from the clutch drive to the gearbox have stripped, along with the spline on the gear box shaft and shear pin.
Also the thrust bearing is worn out.
Are replacement parts available for this model (or Kubota equiv).
Are there any agents with parts for these in Australia?
Cheers
Ralph
Cheers
Ralph
