Well I am one of those owners of a Zeh-Noh ZL1801 AKA Kubota L1801, 2 wheel drive and it has been a great little tractor for me. I bought this tractor 5 years ago for $3900 from a private owner and it has performed mechanically flawlessly ever since.
The only issue I have had was a broken wire from the alternator to the regulator and I had to take the dash board apart to get to the regulator (the wire broke at the regulator) that was a bit of a bear cat to fix and the only other thing was the generic Front End Loader was bolted to the weight box and the welds broke on the front of the tractor.
I took apart the weight box and front end loader and rewelded everything and adding gussets to make it better then what the people that made the front end loader and rewelded the attachment to the front of the tractor, because it was cracking out.
this little tractor has been a faithful servant for me but yesterday I had deliveried a new JD 2305 with a Front end loader, back hoe, and 62 inch mid mount mower. I will continue to use the Kubota as it is a strong little guy and it will do some things that the JD will not be allowed to do as the CFO (read that as wife) will not allow me to do until I have more hours on the JD.
