just came here for the first time and found there was a guy that had almost the identical experience , (almost identical) ,
I was mowing on a bank cutting in a field that was about to be baled , very tall grass, going slow and deck in Travel height . No problems cut like a beast. moved on to a long stretch flat ground still cutting in the perimeter for pre baling but much shorter grass , should have been easier on the zero. ..but..Started sputtering , shuddering then died . eventually got it limping back to garage .
some background for anyone kind enough to offer suggestions:
284 hrs . Recently, oil change , air filters and 3 new fuel filters , emptied and cleaned out fuel tank , ( I have NEVER gotten left side tank to feed so it’s been cut off almost since new, my bro- in law had same fuel feeding issue with his ZD 31 hp)
i always start job with fresh diesel on the right side tank.
also Like somebody else posted here , my trailer holds my 60” zd1211 but not my 72” so I’m going to have to troubleshoot and try and fix to the best of my ability. As the local dealer (the only close by one) is crazy $$$.
thanks in advance for any suggestions
