Hello,
I have a 2021 ZD1211 with 366 hours. I'm doing the hydraulic service and drained the main tank as well as the LH and RH rear axles. 12 litres came out but it doesn't want to fill up properly. I barely have 8 litres pumped in and the level is up to the top of the reservoir. I tried to open what looks to be vent plugs on the axles but didn't make a change. I loosened the axle drain plugs to see if there was anything down in them and some came out but didn't gush out. Manual says to fill SLOWELY and I didn't see that part. I have a high-volume hydraulic hand pump and used that to full it. Seems like a bug air lock but I can't tell. Manual doesn't even mention the vent plugs on the rear axles which I find kind of strange. Any suggestions?
