GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
336 Hours. Oil has been changed 3 times.
I was mowing not real heavy grass. It lost power. I lifted the deck and it quit.
The water temp was normal. The oil is normal.
If you try to start it lots of black smoke. Engine shakes bad.
I locked the brakes and drug it back to the shop.
I pulled the fuel line and it pumps lots of fuel.
I drained the oil and cut open the filter. No metal or anything was found.
I un plugged the stop solenoid. I started and ran for about 15 seconds.
After that it would idle. It did not sound right if you rev it up.
I let it sit for a day.
One injector was dirty on the outside. Maybe a compression leak. I cleaned it with air and brake cleaner.
It sounds good now. I did not put a load on it because it was raining.
I think somehow it got real rich.
