ZD 331 Starter Not Always Cranking
Trkr
65
Baltimore County,Md
Mower has had intermittent cranking issues. Usually, 4th or 5th time it starts. Solenoid kicking in, but not cranking. All connections clean, good battery. Got 10.28 volts, at the solenoid start wire.
Thought I read about starter relay issues?
Thanks.
3,072
YEp... bad relay or safety switch... is reducing current to the starter solenoid. You should see full battery voltage AT the solenoid. I.E., if batt voltage DURING crank-effort is more than at solenoid ...it’s a defective circuit, usually relay or terminals or terminal-to-cable connection.
4,870
1,607
Relay is under the seat behind a plastic cover as I remember.
Check voltage at the starter "trigger" wire. If under 10v, trace it back using voltage drop test to isolate where the problem lies.
I've seen relay fail, but more commonly corroded or damaged wiring.
4,870
1,607
if I remember right, The book doesn't say which of the 3 relays are which. You have to figure it out by tracing the wirings, and matching the wire colors to the WSM's wiring diagram.
dearbobf
Kubota L2600 DT
Jun 1, 2021
Vashon, WA
My L2600 just would not turn over this AM after running fine with 3 starts. Bench test, solenoid kicks in intermittently, or not at all. Are there other issues I should be looking at?
CGMKCM
RVT-1100C, ZD323, L4760
Jan 26, 2021
372
175
Randolph county N.C.
Hold the key in start position and kick/pump the park brake. In my case a safety switch was sticking that would not allow start if brake was not applied. After switch was replaced, no more problems.
