Z723 mower dies/blows fuses
hunt_ak
Z723
Jul 12, 2023
Alaska
Getting the mower going for the season after a motor rebuild and after pulling out of the shed it died and wouldn't restart. Turns out a 5amp fuse was blown in the little fuse box near the seat. Replaced fuse, started, and once I was ready to engage PTO, it blew the 5amp fuse again and died.
Of course the little cover on this is labeled 1-6 but there's no diagram that shows which slot is for what. I found this fairly unhelpful diagram online but I'm not sure which fuse sizes go in which slot and if they are correct.
Also, since the machine died once just slowly backing out (blew a fuse) and then a second time engaging PTO (blew the second fuse), two separate tasks, I'm wondering if anyone has ideas on where to look first.
Two missing slots on the fuse box were both 5amp. Moved the fuse from the far left to the other empty spot and it blew that fuse as well.
3,161
Look at your picture of the fuse block. Just above and to the left is a sticker with information on three fuses. I assume that has something to do with that fuse box. Not sure if it covers all six positions.
It sounds like there is something wrong with the safety switches or the wiring that is grounded and blowing fuses when the switch is activated.
First thing I would do is find a wiring diagram and see what the fuse is for and what wires are powered by the fuse.
Bee-Positive
BX1880, Cab, FEL, Tooth Bar, MMM, QH, Ballast Box
Nov 16, 2022
1,212
1,111
Amsterdam, NY
Not sure if it's similar but looking at the Z724 WSM found here wiring goes from the starter switch to the fuse, then to the safety relay, PTO switch, hour meter, and fuel meter.
hunt_ak
Z723
Jul 12, 2023
Alaska
Yeah the sticker doesn't decode it much for my pea brain. The two empty slots are where the 5a fuses went that we pulled.
I'll dig into the wiring diagram that Bee-Positive linked above.
Hoping the mice didn't get to it! We don't have a lot of mice-chewing problems up here in Alaska but ya never know.
Hugo Habicht
G1900
Jun 24, 2024
1,542
2,238
Ireland
Short of the cables or short within the switches to chassis / ground.
Connect 12V 55W lamp instead of fuse. Lamp will light when short is present and also protect your wires, same way as the fuse.
hunt_ak
Z723
Jul 12, 2023
Alaska
Update: It's definitely the PTO switch somehow (edit: not necessarily the switch itself but related to the electric PTO clutch system). More troubleshooting today but we did verify that it's not the seat switch or other switches. The mower will run and drive and start fine but when you engage the PTO switch for the mower deck it starts to spin up but then blows the 5amp fuse in the middle of the fuse block.
hunt_ak
Z723
Jul 12, 2023
Alaska
Update: More of the backstory here, we just had an engine rebuild on this as one of the cylinders lost compression. During the reassembly of the engine cover a wire was routed incorrectly and came in contact with the flywheel, which shredded the insulation and was causing the ground issue, popping the breakers. Problem solved!
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
271
499
Moseley, VA
I had a similar issue with one of my previous zero turns and found that the pot clutch was the issue. Once I pulled the connector loose it would start and run just fine soon as I hooked it back up ir would blow the fuse and die. Not cheap but a pretty easy repair.
