Z422 Replacement Stud
otb
Kubota Z422
Jun 3, 2026
I need to replace the studs on my Z422 and would prefer not to buy the whole hub assembly since the studs are just press fit. I've determined the studs are 1/2-20 x 1.5" but I am having trouble finding them for purchase. The versions I do find have a different spline pattern. Any help is greatly appreciated. Image (4).jpg
#40Fan
558
389
Spline pattern doesn't matter. As long as the replacement is the same size.
otb
Kubota Z422
Jun 3, 2026
Thank you, I found some Yukon axle studs from Autozone that appear to be the same size, going to give that a try.
otb
Kubota Z422
Jun 3, 2026
What happened to the original studs? I have a Z422 as well…🤔
Complacency, I guess. Two lug nuts fell of the right rear wheel and the last two were hanging on for dear life.
We had a lot of rain recently and my yard is almost entirely sloped so I didn’t get to mow the yard for a few weekends and the grass got fairly tall. When I was finally able to cut it I noticed I was sliding a bit. At first I attributed it to the semi-wet, long grass but after a few passes it didn’t feel right so I brought it back and parked it. The sliding ended up being the wheel wobbling on the hub. It flared out the rim and flattened/sheared off the threads on all 4 studs. I checked the lug nuts end of last year when I did my annual maintenance. Never checked them from then till now. Stupid mistake, and lesson learned. IMG_2893.jpeg
JasonW
762
520
Al
Probably doesn’t help that the lug nuts are on backwards.
10,780
If your going to use that rim still, do put the lug nuts on backwards, but put a flat washer on it first!
The taper on the holes is shot and putting the nuts on the right way will do noting for you.
