Z421 tire issues / advice
Starman2112
Kubota LX2610 / Kubota Z421 54"
Jul 4, 2023
Hello,
I have had my Z421 53" now for 4 years. I mow about a total of 2 acres of normal lawn around my house (not fields, true lawns). About .5 acres is on ~6 different irrigation zones and 1.5 acres goes dry and dies in summer. My Z421 still has the standard lawn tires. The unit has 250 hours on it now.
I live in the pacific NW and our current weather is like this:
Spring wet as hell
Summer dry as hell, no irrigated lawn dies fast in June and is dead until fall rain just starts dumping.
Fall wet as hell.
There is no smooth transition period any more. In summer the grass dies hard and when fall hits, water just dumps on the lawn. Spring and fall are my issues since the grass grows extremely fast and thick and its hard to mow when its not wet.
With my current stock tires, summer is perfect, no problem mowing fast.
In fall and spring, the stock tires immedialy fill up with mud and have 0 traction to the point that I constantly leave tire skid marks everywhere no matter how careful I drive. You know, when you feel the tires slipping and you just start sliding and you look behind you to 2 5 foot long tire sized skid marks in your grass. I even get the mower stuck at time in certain parts of the lawn that have a very short sharp dip and I have to pull it out with my LX2610 tractor and this at times can leave 3" deep tire groves in those areas absolutely splattered with mud. I have no choice in this, the grass is growing so fast that if I dont mow it gets to the point that it can bog down the entire mower.
I’m wondering if there is a different tire I can purchase to fix this issue with more traction. My issue right now is the VAST amount of leaves that are dropping and I like to mulch them with the Z421 instead of leaf blowing for hours and hours. I’ve done some research and I see that there are "lug" type tires. I know these my rip up grass more if not careful but I'm pretty good at operating this thing now and believe I can drive carefully enough.
Does anyone have advice on this because Id like to act on this quickly... like in the next few days.
Thank you for your help.
JasonW
800
554
Al
I previously had a ZG127 with standard turf tires before I upgraded to a used ZD with R4 rear tires.
The turf tires tore up my grass more than the R4’s driving correctly. No issue when it’s dry I just have to be cautious when it’s wet, also due to the extra weight and power of the ZD.
What’s your current tire size?
6,969
get a set of ATV tires for it. They work quite well. ;)
Starman2112
Jul 4, 2023
So, I just mowed / mulched because it actually finally stopped raining for a day and this is what my tires look like immediately. This causes absolute 0 grip at all, even when I’m on firmer parts of the grass and I just leave long muddy trails behind me everywhere.
