You can’t spell “idiot” with out “I"
3,583
Enjoyable read.
Must be the time of year for hand truck tire failures.
About a week ago, I had purchased 3 large pavers, 16" x 24", 53.3lbs each.
Just as I was unloading them, it started to rain, so I grabbed my 35yr old HF style hand truck, (with smaller 4 bolt wheels) and piled them on.
As I pulled it into the backyard, I noticed one of the tires was nearly flat, but in the rain I decided to chance it. (dummy me:mad:)
All seemed fine until I got to the RV parking spot, paved with 1" minus sharp gravel.
Next morn I found the tire was surface plate flat, popped it off, and found 2 cuts in the tube, and several cuts in the tire.
Off to HF, where I purchased 2 new tire/wheel assemblies @$8.99ea, (-15%) and picked up my freebie for that day:
I now have new wheels on this truck, plus a spare for this & my 2nd one up north.
I bought two of these trucks about 35 years ago, and this was the first trouble I've had with either, other than the obligatory airing up once or twice a year.
3,583
I used to teach a beginner level machinist class for technicians who wanted to use our engineering shop.
This was one of the handouts I gave the newbies in that class.
It's a little rough, (been copied about a billon times) but if you blow it up, it's pretty clear:
Sidekick
Jul 29, 2023
1,291
1,883
N.Y,
Getting things constrained really helps for any changes you make in the future. Keeps features and holes aligned making changes easy. I think the full version you bought also has a bolt circle tool in the hole function. Alibre becomes less frustrating to use over time. I just designed my first fully enclosed print using alibre and the K1. Made several versions as I changed my mind and constraints really made the changes easy and painless.
Yooper
3901 LA525
May 31, 2015
1,751
929
NE Wisconsin
Here is a bolt circle calculator that you can use to figure out the diameter.
WI_Hedgehog
Apr 24, 2024
1,130
1,647
Milwaukee, Wisconsin, U.S.A.
I just measure the hub diameter, bolt-hole diameter, and distance between the bolt hole and hub. A bit of simple math and you know how far the center of the bolt hole is from the center of the hub.
Draw the wheel:
c 0,0 (circle center at 0,0)
d 6 (diameter of 6")
Center Hub:
d 1.25 (diameter of 1-1/4")
First Bolt Hole:
c 1.5,0 (circle center at 1.5")
d .375 (diameter of 3/8")
Second Bolt Hole:
co (copy object, select bolt hole)
0,0 (base point of displacement)
0,0 (offset, so two holes on top each other)
rotate (select a bolt hole, which doesn't matter)
0,0 (base point)
72 (angle)
Third Bolt Hole:
(same as second bolt hole, just select the second hole instead)
Fourth-Select the third
Fifth-Select the fourth
In theory you can create a Polar Array or Circular Array, but that's dependent on the CAD program. It used to be Bolt Circle, but by removing that feature and adding Polar Array it's easier to add fan blades in 3-D space and such, so no more Bolt Circle.
Let's try it! Start with one Bolt Hole:
In AutoCAD type Array
select Polar
Center Point (change from to 0.0)
and change the number of items from 4 to 5
Enter
trikepilot
B2620HSD LA364/BH65 48SQ Bush Hog LP FDR1660 LP RB1560 B2672 42in forks LP1266
Jul 18, 2020
205
279
Hardy, VA
All that and you still have pneumatic tires. I swapped my tires out for airless ones and haven't looked back. Got tired of having to put air in the tires every time I wanted to use it.
1000% agree! best move I ever made
Botamon
Mar 26, 2018
492
921
Winnemucca, Nevada
Same here. Both hand trucks, wheelbarrow - all got solid tires a few years back. No more problems!
5,577
View attachment 167948 View attachment 167949 View attachment 167947
I tend to "shy away” from constraints because it seems that every time I put one on place, it screws up my "next move”.
Although, in my heart, I know that I need to get over that.
Advanced users, such as yourself, are always using them. (case in point: my above situation)
Now that I am getting “more comfortable” with the program, I will make a concerted effort to use them more often. (y)(y)
5,577
Draw the wheel:
Center Hub:
First Bolt Hole:
Second Bolt Hole:
0,0 (base point)
72 (angle)
Third Bolt Hole:
select Polar
Enter
Thanks for that "tutorial"
I think Alibre has a similar function.
I will have to give it a go.
Yooper
3901 LA525
May 31, 2015
1,751
929
NE Wisconsin
Gotta ask. What is this? Impressive work!
