Yes, I am a complete newbie and I don't know how to fix a flat industrial tire on the rear of a L3400. Help??
old and tired
L2800 HST; 2005; R4
...I would just put the bucket up under something way to heavy and slowly lift the rear end up instead....
I've lifted my rear tire off the ground way more times than I would like to admit.... And I do have loaded tires.
Problem is finding something heavy... possible chaining it to a tree but by the time you get the chain... you can have a floor jack under there in no time. Good luck...
RichieRich918
Kellyville Oklahoma
Ahh, I understand now. It's the rear tires that have fluid in them that are "loaded". Cool, thank you sir. Since I have no garage or shop or even a concrete surface anywhere I believe I'll go find me a good tree. I've got lots of those. So, thank you and take care!
5,950
Take it to town for $30. He'll check to make sure the wheel is clean, the tire is fine and air it up. Then check the air in the other three tires, they may be low also.
3,327
It may be helpful, when trying to seat the bead while inflating a tire ... to remove the valve-core from the Schrader valve and use a blow-gun to puff a greater amount of air initially into the tire to get that bead blown against the wheel-rim. Then put a finger over the schrader valve to keep it inflated so you can quickly re-install the valve-core... and then finish inflating it to the proper inflation.
1,550
I'm glad you mentioned how you used the bucket as a jack because I had already had an idea that's the same thing only backwards. I was thinking I would just put the bucket up under something way to heavy and slowly lift the rear end up instead. It doesn't have the fluid in the rear tires as of yet so it's pretty light in the ass. Lol Since my step dad got too old and frail, he recently handed the tractor and the responsibilities down to me. They say give a difficult job to a lazy man and he'll find an easier way. Lol I just don't know if that's actually a good idea or a recipe for disaster! Can I do it that way then use the car jack's for safety purposes?
Not very safe but at least block it up and then let it down on wooden blocks (cribbage) so it can’t crush you regardless of how you get the rear weight off the rear wheel.
3,067
I would just add that if you would use a liquid tire sealant and later have a puncture that requires something like a patch on the inside of the tire, tire shops may not want to deal with the hassle of cleaning/prep required to install a patch.
Myself, I view those liquid tire sealants as a temporary, rather than permanent fix. I do not use them.
Bmyers
May 27, 2019
3,338
3,943
Southern Illinois
Excuse me Bmyers, a question. The product you suggested, I see that it is a sealant but don't I need that trick where they make the small explosion while simultaneously putting air in? Or something like that.
Yes, the product I mentioned isn't for seating the tire. Typically, I try to avoid using those type of products, but I do keep them on hand because sometimes you have to keep moving forward and clean up the mess later.
i7win7
Feb 21, 2020
3,378
3,983
Central, IL
The safer / professional tire shop way
RichieRich918
Kellyville Oklahoma
remove and take it to a tire shop or local garage, might cost $20 for them to reinflate.
If the tire was a wee bit low on air pressure, the 'tug' of pulling something heavy , could have spun the tire off the rim. It'd be a real good idea to test ALL the tires now for proper air pressure. Air leaks out over time..one of them 'physics laws' we tend to forget......
Yes, can't get around them 'physics laws'. 😃Thank you for your input sir.
RichieRich918
Kellyville Oklahoma
Now this looks exactly like something I could use!
Absolutely brother. There's no substitute for safety. Thanks for the advice.
