XXL Amish Q-Tip
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,114
1,230
Near Lancaster, PA, USA
I picked up another plastic drum for fuel storage. It was used for olive oil and was drained but not washed out. Rather than fiddle with water or solvents I decided to remove as much of the olive oil as possible. The drum sat in my one shed for a couple weeks, so nearly all the residual oil was in the bottom around the outside of the drum. I thought it would be fine if there was a way to wipe it real well with a rag. Poking around the shed I found a piece of plastic pipe, rags and a spool of string trimmer line.
The string trimmer line was fed down through the pipe double and what came out the other end became a snare to grab the rags. Changing the rags was as easy. Just a matter of letting some slack in the line from the other end. It took only a couple minutes and 3 or 4 clean rags to mop it dry. I'm not concerned about any small amount of film the olive oil may have left behind.
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
Ingenious !
And so what if there's a dribble of olive oil in there.
You can brag to your buddies that you "make biodiesel"
2,965
I am trying to figure out what the Amish have to do with your innovation! :unsure:
Maybe because it does not use air filled tires? OR electricity...
Edit: we do not have Amish locally, but do not too far away, maybe an hour or so. Do they actually make their own Q tips? Inquiring mind wants to know...:)
forky
L2501 HST 4X4 8N
Feb 23, 2021
266
275
Wisconsin
My neighbors are Amish.....good folks....they buy Q tips like you and me. They also have the best guns in the woods, and are great neighbors that actually have respect for others around them.
OrangeKrush
Nov 15, 2020
1,047
515
Indy
Ingenious !
Yeah may be the best your tractor has ever run!😊
bbxlr8
Mar 29, 2021
381
245
Eastern PA
I get it living close enough to OP. Henro; it's about being frugal and totally a compliment in my book. Love it!
chim
Jan 19, 2013
2,114
1,230
Not meant as a slam toward the Amish. When some people see I live in Lancaster County PA, they assume I may have an Amish connection. The "chim" comes from the local pronunciation of Jim :) Been using it on different boards for years.
chim
Jan 19, 2013
2,114
1,230
Actually, my Stepdad did make his own Q-tips when I was a kid. We always had a bulk package of cotton in the medicine chest. If I recall correctly it came in a small cardboard box and was rolled inside blue paper. He had ear problems and he'd twirl a flat sided toothpick in cotton to apply whatever the medication was. He wasn't Amish though.
2,965
Are you the Chim I remember from years ago at TBN?
Always figured it to be so, but never thought to ask...
chim
Jan 19, 2013
2,114
1,230
That would be me. Still frequent TBN and Rimfirecentral. Years ago there was a great board called Shooterstalk that went away and I miss it. Been on a few others but in recent years it's been mostly here, TBN and RFC.
In the avatar you had with you wearing the big hat, you look a lot like a guy I worked with.
PS: Back around '78 I worked near Zelie for several weeks.
