Hey guys , I'm looking for a loader and backhoe for my 7100.... anyone selling
Yah I picked this up yesterday , 7100 from original owner with 500 hours . 3k , figured that was fairYea I'll second what 85Hokie said!
So I found a newer 7100 with a loader and mower deck for 2600, motor has blowby and won't start , I think that's a fair price for everything. Everything is in great shape and everything is completeIt's probably fair. Get yourself a 3pt scoop and a carryall and a hitch adapter. That's about the best you'll be able to do. I love my 7100, but it's basically just a small trailer puller.
I still expect to keep the 7100 around and pass it down to my son, hopefully. Love that stupid little tractor.
I'm a really good welder, tig and mig . So I found a 7100 with a loader and mower local to me . It's in awesome shape , it just has a blowby issue , he wants 2600 for everything delivered. Im going for it . It's 100% complete in great shapeThe Kubota loader options for that tractor are the B219 OR the B1630C. The backhoe is the B4672. A subframe is also required as part of the FEL and the FEL is required for the BH. All are rare as hen's teeth these days. Murphy's Law says that if you do find a FEL it will have been attached to a different tractor originally and will therefore have the wrong subframe, requiring modification to fit your tractor.
Of the two, the FEL is by far and away the most useful attachment I have but I had to make my own. (My build thread is here. Others have done the same). I incorporated Skid Steer Quick Attach into my build and get almost as much use out of my home made pallet forks as I do the bucket. You will also need to either obtain a separate hydraulic pump and reservoir (usually incorporated into one of the FEL support towers) or tap into the tractor's hydraulics with a suitable replacement hydraulic block cover if your tractor has the block (see this thread for more info) -- or by tapping into the lines if it does not.
I did manage to find a B4672, but it took 4 years of looking. I had considered building one of those too, but wouldn't get the use out of it to justify the time. Now that I have one, I have put it to use and it's handy to have but not nearly as handy as the FEL. Your Mileage May Vary. If you do find one, you will need a Heavy Duty 3PH top link bracket. Also no longer available. My build thread is here.
How are your welding skills?
