Would you use B7100 without hood
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Trying to restore badly rusted hood to make it look great again, and I have now lost good weather & temps to finish priming and painting hood.
Trying to decide weather to just spray a quick coat of primer in cold temp and hope the paint holds out til spring, or run without hood to clear snow this winter.
Having mixed feelings about running in wet conditions without hood. Trying to do a sanity check. Comments appreciated...
Thanks, Dan
gktilton
B7500 with Loader and MMM. Woods M4 Bush Hog, Kuhn Rototiller, 3PT Snow Blower
May 5, 2010
234
Hooksett, NH
I would do a quick spray of anything onto it and put it back on. Anytime I leave something like that laying around the shop for the winter I end up damaging it.
ETRon
M6040
Aug 4, 2010
128
Tellico Plains, TN
I'd have to rate storing it inside most important. You could probably get away with running it without a hood but I'd suggest an alternative I've done myself when in a bind. Bring the hood inside or a place where you can warm it up well. Take it outside to spray, quickly, should take only a minute of two. It'll be okay if spraycan and hood both are warm. Bring it back inside to cure for 24hrs. This isn't a good idea if you heat with open flame, at least if you have the hood in the area or if the wife's home. I've brought painted parts into the house to cure after the paint "flashes" for a couple minutes. If you have a gas furnace in the basement then leave it upstairs for a bit. After 15-20 minutes most paints aren't venting enough vapors to be a problem.
