Hello all - I found this forum searching for help on a problem I have with a front end loader on my tractor.
I never had a loader before and last year I picked up a B1550 with the FEL. My experience has been mostly with gas cars, not diesel tractors, and I never had a hydraulic attachment but it comes in handy! I've used the loader a few times.
A few day ago I use the B1550 with loader to scrape snow off of my driveway. Worked great over about an hour of use. I decided I'd clear some snow off the streat, and as I was using the loader the UP / DOWN lever got stuck. The joystick moves fine right-left to curl an dump the bucket, but the joystick won't physically move up or down. Of course it gets stuck down, and I have to have someone literally pull my tractor out of the snow as I dragged the buck sliding on the ice/snow road back to the house since I couldn't raise the bucket off the street. I go home and checked the fluid level and it appears okay.
My question(s).
Is this a common problem?
Could there be something wrong with the hydraulics causing the valve to lock?
I had no luck searching for a replacement valve assembly if I have to replace it - any aftermarket do? (spec says 5 GPM) Suggestions?
Once it warms up a bit more I plan on pulling the valve assembly off the tractor - cleaning it up and inspecting. I'm hoping I'll find something simple and mechanical causing the lever to no work, but I won't know until I put my eyes on it.
Thanks for helping a newbie!
My question(s).
