Woodpeckers are doin-me-ead-in!
58Ford
BX23s, LA340, BT603, RCR1248, PFL1242, STB1072
Jan 1, 2022
248
203
SW Washington
I have at least one that’s taken a liking to my patio posts. Anyone have any suggestions on handling this? Open to all suggestions. Prefer humane if possible. I had just finished patching up the last set of holes. This guy has me working non stop, patching and painting!
We are a little rural and on acreage but no trees within 300 yards of the patio. Very open terrain. If that matters.
4,304
A few suggestions:
1) Make absolutely sure you don’t have insects in the posts (termites, ants, carpenter bees, etc.). Woodpeckers are generally better at finding insects inside wood structures than people are, and they generally don’t return to unproductive spots. However you could be dealing with a crazy dumba$$ woodpecker.
2) If it doesn’t ruin the aesthetic of your house, get a siding guy to wrap the post in aluminum.
3) Replace the post with aluminum or fiberglass.
4) Shotgun. Putty and paint one last time.
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,411
1,691
Kalamazoo, MI
I had a crazy woodpecker that was destroying a sparrow trap made out of green treated marine plywood. Trust me, there were no insects in that wood. He was just hell-bent on destruction!
58Ford
Jan 1, 2022
248
203
SW Washington
Thanks NCL, I had not considered there was bugs in a 5 yo post. Well worth the check!
There was a couple hanging around when we bought the place. Banging on the roof flashing and then started on the posts. I think this guy was their youngin.
I did try the woodpecker feeder to try to tempt them away from the house but no success with this guy. A year ago I stopped all the feed because of how frustrated I was and likely made it worse because of the feed. No idea.
Thats the reason I have hesitated chootin him. But he’s pushing his luck!🤣
58Ford
Jan 1, 2022
248
203
SW Washington
Yeah, my guy may be related. I didn’t build this place but pretty sure the posts are just treated 4x4 with 1x4 planks on the outside, all primed and painted house color. He’s tearing through the planks. Can put your thumb in them.
5,070
Boom !!!!!!
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
658
535
E.
aren't wood peckers (like bald eagles) protected in the US?
In my area in Canada not uncommon to see dozens of bald eagles and wood peckers etc... at a time but a strict no no to shoot both.
imnukensc
BX2380
Sep 10, 2015
692
600
Midlands of SC
In general, the only birds not protected by the Migratory Bird Treaty Act are house sparrows, starlings, and pigeons. It's even against the law to possess the feathers of birds that are protected. Wouldn't stop me from killing a woodpecker that was destroying my house, though, and I'm not gonna get rid of all the barred owl feathers I've collected out of my yard.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,147
1,266
Near Lancaster, PA, USA
A little different bird problem several years ago. Wifey's car somehow got chosen by as a target by just one bird. Never understood how one small animal could produce that much excrement in such a short time. It began with birdcrap on and near the right side mirror. The situation kept getting worse. When it got to the point where the side of the car regularly looked like the picture below, she put a contract out on him. One of the boys obliged. One dead bird, no more poop.
Tarmy
L2800, BH76A, FEL,box scraper
Nov 17, 2009
481
405
Lake Almanor, Ca
We had them real bad..tearing 2-3” diameter holes in siding and doing a lot of damage. They are very common up here and most folks use fish netting, metallic streamers, fake owls and pellet guns. Nothing would stop them. One guy asked if my house was a dark color…why yes! Painted the house a light tan, from the dark brown it was, and the problem almost completely stopped. They actually moved over to the neighbors…but he shoots them so that seems to be the most permanent solution.
5,686
They set there looking at themself in the mirror. I think they see a mate?
6,594
Plant some trees for him to peck on.
Or just plant some dead tree trunks.
2,636
posts #18 & #20
Daferris
LX2610
Nov 23, 2021
483
404
Mid-Michigan
I had the same problem years ago. Look for some stuff called "tanglefoot" it's a sticky paste to smear on the spot they are drilling had to do 3-4 places but after a week they moved on and while they go after the dead/dieing trees around here they have left the house alone.
5,040
Bird-X is one electronic method. Disney was banned from using them as they kept ALL the birds away from the food courts. Simple, effective.
Freeheeler
b2650 tlb
Aug 16, 2018
706
523
Knoxville, TN
The carpenter bees are my initial problem, I hunt them vigorously with the tennis racquet. The woodpecker is after them too I assume, but he's not getting rid of them, just making a bigger mess. I'm hoping if I replace the damaged wood with Trex or similar, then both problems will be solved. If not, it's boom time.
