Wood Chipper...PTO or Independent!
4,537
Hydraulic feed isn’t a time saver. It’s a control feature that enhances performance and safety by allowing quick reversal of feed, control of feed speed, and hands off feeding. Why are those things important?
Quick directional changes. The obvious is of course if your clothing gets hung on a branch, it’s preferable to reverse feed rather than being chipped to death. Less obvious, but more common in my experience, a branch rotates such that an attached branch or joint jams the feed chute and all it needs is to be rotated a bit to feed right. Reverse, rotate/rearrange, reverse again, continue chipping. Very rare, if ever, need to shut down to clear a feed chute jam after a little practice so long as there’s either enough still outside the chute to safely manipulate it or you have another limb to be chipped to use as a manipulating tool.
Feed speed. The other type jam is discharge chute clogging. Sticky, sappy stuff like Eastern Red Cedar, most any kind of pine; if fed too fast the chips can start to clot like red blood cells and totally block the discharge chute. Slowing the feed rate will alleviate clogging with sticky, sappy stuff. It can also assist with engine bogging if you’re pushing the limits of HP with large branches. Drier wood, hardwood that isn’t so sticky, smaller stuff; up the speed.
Hands off feeding. There are systems other than hydraulic feed that allow hands off feeding. Not aware of anything other than hydraulic that also allows variable feed speed and near instant reverse. In my experience, having your hands, particularly having a good grip, on brush/branches as they engage the chipper knives is less than ideal. The bigger the chipper and bigger/harder the thing being chipped, the worse it is. When a chipper is reducing, for example, a 5” piece of hickory into chips, the knives are hitting it HARD. Even with smaller stuff, if you’re still holding things while they’re engaging the chipper knives, that impact is to a greater or lesser degree translated into your hand/arm. Unless you chipper use is infrequent, short duration, and you are both young and healthy, I would recommend against anything that doesn’t self feed.
UnEasyRider
L3302 LA 526 loader, Box Scraper, Grappler, Forks, Rotary mower, Big Tool Rack.
Apr 14, 2023
136
68
Florida
What I meant by time saver I thought you manually had to feed each branch. Figured not having to do that would be a small time saver as you could be getting the next branch. Never used one so my ignorance abounds. I really appreciate all the good info you took the time to give me!🍻
mikester
M59 TLB
Oct 21, 2017
3,757
2,314
www.divergentstuff.ca
Thanks for this discussion. I am in the same quandary. I am leaning toward a PTO drive on a M7060 as I have a large area to do with old Xmas trees, so I can set up and chip in one spot.....on the back hill away from the "things to do list at the house"!! Thanks again for the inputs.
Rent one of these and grind those christmas trees in place. You will thank me later.
Chippers on the tractor are nice to have if you take down a couple of trees and want a quick clean up. Burning isn't always an option or convenient.
If you have a lot of small trees to cull grind them where they stand with a 100HP 5 foot wide portable chipper. You can grind 12-16 foot trees in seconds.
BoilerBoy
M7060TH12 w/FEL, B2920 w/FEL B2401/FEL, B7100 w/60' deck,
Sep 22, 2020
Indiana
Good point....this is definitely an option and one I have considered but I am also justifying a $40K M7060 with the clearing
Yes this is a much better option but I am also justifying the M7060 purchase thru the clearing angle. I do plan to check this option out as a neighbor and I can share the rental
BoilerBoy
Sep 22, 2020
Indiana
Yes this is a much better option but I am also justifying the M7060 purchase in part thru the clearing angle. I do plan to check this option out as a neighbor and I can share the rental. Thanks for the tip.
Knuckle_Head
Kubota L6060
May 5, 2023
17
I have the woodland mills 8" chipper for my L6060 and love it. Just spent memorial day doing a neighborhood project of cutting and chipping mostly small trees along our private road to keep them out of the power lines. Ran it for 7 hours and it chipped everything from small branches to 6-7" trees. Gotta go slow with the small green firs as all the needles tend to clog it, but keeping that in mind it works great.
You can probably guess which side Im on. PTO all the way.
UnEasyRider
Apr 14, 2023
136
68
Florida
Thanks for your imput! Is that one hydraulic feed and US made?
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
How much, how big and what kind of wood?
I cut fire wood so I'm trying to stack anything I can down to about 1.5 inches depending on how twiggy it is and burn the wood chips. So I'm chipping mostly dry to kiln dried elm because I don't want moldy wood chips. Also need to be ready to burn.
Being a wood chiper is a hard life. I wouldn't want one on the back of my tractor. PTO Wood chipper and PTO stump grinder are both an easy "no" for me.
I say get a wood chipper thats belt driven and has at least 300ish cc's 8 to 9hp.
I found my woodchippers original little 6.5hp 197cc engine was lacking power even for small stuff.
Anything with the cutter head mounted directory to the engine is going to suck. I already destroyed one direct drive chipper and remade it into an over powered belt driven monstrosity with my old oil burning Honda gx390, which is about to get replaced with a predator 459cc as soon as it stops raining.
re: I have yet to have a chipping emergency where I absolutely MUST chip something IMMEDIATELY.
That's cause you ain't married to my WIFE !!! :oops:
Never know.
Knuckle_Head
Kubota L6060
May 5, 2023
17
Well, thanks to you I feel dirty about it now. I (dumbly) assumed it was made in Canada, but im old enough I should have known better. :)
With that said, having about 30-40 hours on it, I would still recommend.
jkrubi12
B2601/LA435/QA54"/BH70/B8160box/BB1254/PFL1242/SGC0554/BX2812APlow/WC-68 Chipper
Sep 24, 2012
403
299
right coast
Yeah, the Woodland Mills WC-68 is made in China, but it a heavy-duty SOB and it works very well. 100 LB cutter wheel w/4 cutting blades, hydraulic feed, safety bar, feed chute folds up for compact transport or storage, very well designed unit IMO. Hydraulic feed is a must for a machine of this type; I generally transport my chipper to the pile & chip there. Very happy with my chipper, highly recommended!
5,519
It'd be dang difficult to find anything without 'Made in China' parts in it. Kinda nuts that heavy things can be made there and shipped here for less than truly 'Made in Canada,eh' !
Oil pan 4
L185 turbo
Sep 21, 2017
418
118
NM
How are you going to use this wood chipper?
Size of wood is most important?
How much wood, how often?
What species, green or dry?
Thunder chicken
M7060
Dec 29, 2019
295
120
Northern ontario
I have a woodland mills WC-88 on a M7060. The flywheel is belt driven so any nasty load is off the PTO as someone mentioned that. It has its own hyd pump for the feed, so not using tractors like a few other brands.
The 8" opening is where it shines, you don't have to trim as many limbs or worry about the crooked pieces as much, as it'll twist and bent through the hole, especially with fir.
And having the AC on in the cab while chipping gives you a close, cool spot to take a break cause you can run yourself off your feet keeping it fed.
grsiepka
BX23S
Mar 1, 2022
Grantham, New Hampshire
Fwiw I was in the same debate recently, made a thread on reddit over in /r/kubota and got mixed responses based on my tractor size (bx23s). I ended up picking up a Woodland Mills WC46 chipper that is PTO driven based on a suggestion from someone there. It's rated for up to 4" logs (like many say anything bigger than that is firewood) and has taken everything I've thrown at it, has not bogged down and as long as your not throwing small pine branches thru it (smaller stuff tends to just get sent right thru) it make really nice chips if you're planning to use it for mulch. It's way over engineered, super heavy steel flywheel, has a hydraulic infeed, reversible blades and looks like it will last a lifetime. I've got about 16 hours on it so far and absolutely love it. Cost was 3k with shipping to my home in NH. Second pic below was during assembly without the discharge chute.
jkrubi12
Sep 24, 2012
403
299
right coast
Welcome to the forum @grsiepka, I feed my chips into an identical trailer as yours (Ohio Steel); my blueberry bushes love that stuff!! :)
