Will this tube fit?
Phoebus
BX2670
Mar 20, 2015
Nova Scotia
I've got a BX2670 with turf tires. One of the fronts has a gash on the side wall that is no longer being sealed by slime. Rather than replace it, I'd like to try a tube.
The tire size is 18x8.5 10, but the closest tube I can find is 18x8.50/9.50-8. Will I be able to squeeze the 8" tube over the 10" rim?
Phoebus
BX2670
Mar 20, 2015
Nova Scotia
I should clarify, the rim/bead diameter is 10", but the inner diameter of the wheel is much smaller. If I could squeeze the tube over the outer bead, then it would probably sit loose until it was inflated.
I'll look into the ATV sealant too.
Phoebus
BX2670
Mar 20, 2015
Nova Scotia
Thanks. I ended up pulling the tire off the rim and patching it. So far its working fine. (although getting the beads to re-seat was a hassle)
JoeR69
BX23S
Nov 15, 2023
NY
This is an old post but it comes up first in goggle searches so I figured I'd post a helpful reply.
18x8.5-10 means 18 inch diameter tire, 8.5 is the tire section width -10 means the rim is 10 inch diameter. So question is will a 18-8.5-8 tube fit. The 10 inch rim diameter is larger than an 8 inch rim diameter so an 8 inch tube will actually be a little over sized as far as space (i.e. it has some slack).
So will a 18x8.5/9.5-8 tube fit?
Yes they will. I put them in my tractor tires 3 years ago and haven't had any issues.
This is for TUBES! New tires have to be the same rim diameter.
