Hello folks,
So over the past week I have been painting the house and needing the garage so every day my wife takes my B2620 out, parks it somewhere in the yard and at the end of the day she puts it back in the garage. She basically putts around at idle or a few 100 rpm above idle. This weekend I noticed slow cranking but the tractor started. I then noticed it just clicked, like a dead battery. So I put a charger on it and for the hell of it tried to start it and it immediately started up strong. HMMMMMM???
Battery had a dim yet visible green eye and so I left the charger on 12V 10A setting and it was pulling about 8-9 amps so the battery was discharged a bit. After a while and being impatient I started the tractor and put an inductive pickup ammeter over the positive battery terminal and was reading 7.1 amps at 2400 rpm so I knew the alternator was good.
I think the battery is good as well as the charging system. I left the charger on overnight at the 12V 2A setting and this morning it wasn't even registering any current which indicated a full charge.
My hunch is that NOT running the tractor at sufficient RPM over a couple weeks was just bleeding the battery because the alternator will not charge at lower RPM...or the tractor depletes the battery faster than the charging system can charge at idle or lower rpm's. And it was just a matter of time before i got the dreaded click.
So is my hunch fundamentally sound or could I in fact have a bad battery or charging system component?
PS: Up until these past couple weeks I have had absolutely ZERO issues; the tractor has been performing flawlessly...
Thanks...Burgie
Thanks...Burgie
