Widening the tires on an L3000F
hank2000
Kabota L3000F
Aug 27, 2016
81
louisville
On my L3000 I need to make my rear tires wider the width that they are from the factory I can't use the sway bars o got from Mark because they are wider then the turn buckels that came on it but with the rear tires spread out they work perfect. So my question is do I need to widen the front tires as well or will they be ok like they came from the factory and if I need to widen them how do I do that just take them off and turn them around or is there some other way you have to do it
Thanks
5,440
What size tires are on it now?
On the 2wd's there was an option of set of rims that are reversible for row spacing.
hank2000
Kabota L3000F
Aug 27, 2016
81
louisville
I will have to look tomorrow and see what size are on it. I know the rear can be spread out but not sure about the front. Can't tell if the front are reversible or not. I don't know what reversible rims on a tractor look like
