Why are my hydraulics weak?
ken erickson
Nov 21, 2010
1,147
1,857
Waupaca Wisconsin
Welcome to Orangetractor talks!
Lots of very helpful and knowledgeable folks here to help you out but a lot more information is needed for meaningful responses that will answer your question.
Information such as model, gear or hst, hours, history of fluid changes, parts replacements, which hydraulics? three point, loader, hst or rear remotes.
It will also be helpful for you to qualify your term “weak”. Example, weak compared to normal operation, or weak compared to other similar sized tractors etc.
3,309
Low fluid, clogged filter all kinds of stuff,, like askin why your erection isnt erection
3,309
OK now what do you mean by weak? Is it not doing what it did before, have you changed filters and fluid, have you crashed it,, a lot more info make the getting answers a lot easier
cthomas
LX2610 HSDC
Jan 1, 2017
865
579
La Farge Wi
WOW, Ok now what tractor are you talking about? Is the engine running? Does it have fluid? Are you operating the joystick for the FEL?
ve9aa
Apr 11, 2021
1,202
982
NB, Canada
Like pullin' teeth........🤪
tony bryant
L2550GST and M9000
Jun 24, 2023
ft worth tx
No, thanks for asking. The small tractor will not pick up a bucket of dirt. The grapple will close, after I use it awhile, it will not open back up. (L2550)
The big tractor will raise the box blade, but within 50 yds its dragging. M9000 I changed the filters and hydraulic fluid on both these.
4,495
So you have two tractors with hydraulic issues?
in any event drop $20 on a 5000 PSI hydraulic pressure gauge and start checking pressures.
animals45
L3301l
Apr 22, 2021
269
84
Mabie CA
Tony , did they both just start having this problem ? Was it there before the hydraulic oil & filter change ? What did the old fluid look like when you changed it , any metal shavings or did it smell like it may have burned ? What hydraulic fluid did you use ? If you lift the loader to the top of its reach power the tractor off & see how long it takes for the loader to bleed down .
animals45
tony bryant
L2550GST and M9000
Jun 24, 2023
ft worth tx
Hydraulic oil was dark and ugly.
The L2550 has been having problems for a long time, 1year.
The M 9000 just started the box blade drop. It's a big box blade. It did better after the Hyd oil change.
I'll try the pressure gauge.
3,680
is there a valve that controls the 3PH drop rate like on our smaller machines? (Ours is a knob beneath the seat).
If so, try closing that valve some on your M. Since you say that its a really heavy box blade, maybe the bounce is causing it to drop?
4,495
animals45
Do you know what you are looking for and where to look with that gauge?
