Who has the best way to deal with leaves in the fall ?
koja
BX25D
May 27, 2014
335
Fremont Mi.
I have a friend who bales them- I help him every fall. He has a LOT of trees- probably 40+ big oaks around his yard- so baling them is the best solution for him. He uses the bales for his garden, and gives some of them away. He uses a hay baler, and we rake the leaves into the chute (it doesn't pick them up like it does grass).
Those bales weight 120+ pounds a piece, and have a LOT of leaves packed in them. I would guess that an 8 foot pickup bed couldn't hold all of the loose leaves that would go into a bale, and he gets 75-80 bales, every year.
It isn't for everyone, but it works well for him. It takes about 6 hours to blow the leaves into wind rows, bale them, then load them on a trailer.
Hmm , interesting idea .
ShaunRH
L3200
May 14, 2014
1,414
Atascadero, CA
I have heard you can pile them all up, cover them up with dirt and burn them like you're making charcoal. Then you rototill the dirt and left over coals, add some nutrients your particular soil needs and it's awesome fertilizer.
Never had enough to do it with to try it but I want to!
Eldubya
B7800FEL Bck hoe Box scraper Post auger Field rake
Apr 14, 2014
92
Quadra Island BC
Certainly not the 'easiest', but I blow them into one area, then mulch and bag them with the walk-behind mower. Combine that with a 50/50 mix of seaweed off of the beach in front of our place. Run it all through the chipper/shredder and I've got one of the best, nutrient rich soil additives going.
Bit of work, but well worth it for the garden.
OklahomaBill
B7300
Sep 17, 2014
17
Oklahoma
I let mother nature deal with em... She has a bit more experience. Somes times I help her along by tossing them in my horse manure compost pile
alansz400
B7500. FEL, Piranha tooth bar, box scraper, post hole digger, 3 pt. bucket
Oct 26, 2013
265
Loudonville OHIO
Here is my set up for this year. Works great. Even picks up those nasty chestnuts.
84cj
Bx1800, 60 inch mower, front snowblower and bucket.
Aug 8, 2013
76
Gorham, Maine
Prior to the kubota, I had a riding mower with a bagged. Ride around and suck them up. Dump them in a pile in the woods. That finally died, rod thru the block (it had a hard life). Now with the Bx, I have a rake. I'll blow them into a pile with the Bx, spen military type trailer on back. Rake them up, put them in the trailer and dump.
6,001
I've got one of these. I'm modifying it to use the 3PT the PTO for power. No engine to maintain. Only maintenance parts are the rubber fingers. Original cost was in the $20,000 dollar range, but have not been manufactured for about 20 years. They were made about 25 miles from where I live and there are a few of them around.
http://www.youtube.com/watch?v=kXgqzON0nj8
7,199
That thing looks like a zamboni for your yard:D
Tooljunkie
May 13, 2014
4,150
D2Cat has what i have been dreaming of. Perfect for harvesting crop residue. Then i pelletize it. Soybeans burn the best so far.
Awesome machine. I like those unique ones.
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
The effiecent way to mulch is to block off the discharge shute with some sorta sheet metal. Depending on the size an old license plate can be use or any kind of sheet metal you can bend by hand.
Blocking off the discharge shute the leaves get chopped up a few more times by the blades and diced to a pulp.
Donystoy
Dec 10, 2013
630
281
Binbrook, Ontario
I built this vacuum a few years ago that attached to the mower deck (not in picture). I sold it some time ago when I purchased a riding lawn mower with a smaller vacuum setup. The homemade one worked great but took up a lot of storage area even though it collapsed to 22" wide.
We use to take a weeks holiday every fall just to clean up the leaves. We have 3/4 of an acre which would have leaves as thick as 6" in some areas. Blowing them away was no option as we have hedges and fences in the way. The smaller unit works fine now since we have lost a lot of the trees.
I also bought a small hand blower/vacuum that works great in awkward areas such as flower beds.
