Wondering if this tractor has any way to switch to 540 vs 1000 pto. For some dumb reason it has 1000 and 1000 reverse. Not sure if it can do 540 or not.
No but there aren't any unaccounted for. Not that I can findhttps://www.tractordata.com/farm-tractors/000/5/6/566-white-2-105.html
Says it has 540/1000. Got photos of the gear shifters around in the cab area? More the merrier....
www.reliableaftermarketparts.com
It seems to me the tractor should have two sets of gears in the PTO housing. You remove a snap ring on the back, pull out one shaft and install another to change speeds. One shaft engages one set of gears, the other shaft engages the other set of gears.
158281A PTO Output Shaft 540 RPM for White 2-85 2-88 2-105 2-110 ++ Tr
One New Aftermarket Replacement 540 RPM PTO Shaft Fits White / Oliver / Minneapolis Moline Tractor Models: G1355, G955, 1750, 1755, 1850, 1855, 1955, 2-105, 2-110, 2-150, 2-85, 2-88, 2255, 4-150Tech Info: Length: 9.970"6 Splines (output) 21 SplinesPart Number: 158281A,158281Nwww.reliableaftermarketparts.com
I was very confused I put the stub in the other slot and hooked up a pump and I was like..... reverse????? Why would anyone ever want reverse. I just assumed it was 540I'd have to say that I've never seen a reverse on a PTO!
I have to look it up the reverse pto slot exists for specific things for loading grain I guess. It was an option apparently.The two speed Whites I’ve dealt with (very little) work like this:
Not swearing that’s how the 2-105 works. I think the guy in the video is demonstrating on a 135. But your pic shows 540RPM splines running 1000RPM? And a reverser?
I’ve never seen one with a reverser. Looks like you’ve got a pretty weird setup there.
It's a 540 shaft that spins 1000. They do that for low load things because you can idle the tractor to run it.I’m confused by your question!!! You are asking if the tractor you posted a picture of can use 540 because it has 1000, but the picture you posted is 540 PTO shaft!!! Is your picture not the actual tractor or are you confused??
