Which oil filter for
ynot47
L405 DT
Aug 15, 2016
Christchurch
Hi all I am in NZ and have a Kubota with the 4 cyl V1902 motor. The oil filter has no info on it.
If anyone out there has filter brand/part number it would be much appreciated.
Thanks Tony.
2,863
mattwithcats
784
77
A Fram PH7328 should fit...
But that’s a bottom level economy filter...
If you have room, a Fram XG16 is just a little longer,
And
A Fram XG8a is even longer...
The 16 or 8a will be easier to find too...
(Using Fram as a reference, you can convert the Filters referenced to other manufacturers....)
9,149
Are you sure it's a V1902 and not a V1901?
The exact number and serial number can be found stamped on the block just on the flat next to the injection pump facing up.
The reason I ask is I don't think the V1902's came out till they switched model #'s to 4 digits, But there are a ton of oddities in kubota and especially with Grey's. :D
There is actually 2 V1902's out there.
I would need to know if it is a IDI (indirect injection) or DI (direct injection) engine.
The IDI engine will have fat short injectors, and the DI will have long skinny injectors.
V1902 IDI
V1902 DI
Also, does it have a spin on filter or a cartridge filter, and where is it attached?
