Where to mount.
Whatscooking
Grand L 3130. BX2360. RTV900. GRASSHOPPER 721D
May 19, 2021
124
62
Indiana
I ordered A wicked 55 grapple. They have sent the 3rd functiin valve ahead of time so i unboxed it and laid it out. Which side of the loader do i put the connects up front? Does the grapple come with the hoses preferring one side or the other? And do you orentate the bracket foward or to the rear?
mcfarmall
Kubota M5660SUHD, Farmall C
Sep 11, 2013
1,385
1,657
Kalamazoo, MI
Typically your 3rd function lines follow the other hydraulic hoses up the loader frame on the right side of the tractor.
ctfjr
L3800HST
Dec 7, 2009
1,723
1,948
central ct
I guess you could change it but it was most convenient to run on right side.
I used Bird Dogger's bracket. To be 100% here I use a rear remote valve here and just run the lines next to the fel lines.
Whatscooking
May 19, 2021
124
62
Indiana
Thanks for the pictures. Apperantly the valve mounting is a little different for different loaders. I have a 723 loader on a Grand L 3130. The bracket for the electric valve is going to bolt on nicely with the lines all underneth the loader valve.
Whatscooking
May 19, 2021
124
62
Indiana
The valve tucked in nicley and the lines are hooled up.
The instructions say to run the hot lead directly to the battery. I have searched and don't see any pigtails to get a key on lead. Does the ignition switch have screws or are they a push on spade type?
