Where is Your Tractor Kept?
BAP
Dec 31, 2012
3,171
1,291
My B2920 is kept in a bay I built for it when I built a new SugarHouse.
9,117
Mines out in the weather in the back yard. Would love to have a storage place for it, but right now it's not in the cards.
Sent from my SM-G920V using Tapatalk
Howling
BX2370
Feb 5, 2016
217
10
Ayer, MA
Mine is in Shelter Logic Garage behind the house. Past due for new tarp to keep out the rain. lifted it up on a couple levels of 4x4s last year so now the ROPS just drags on the rolled up door.
Cathy Liebchen
KUBOTA M7060, MX5800, MULE PRO FX, MULE PRO FXT
we keep it in a home made run in shed. Build identical ones at the mountain house and at the farm- they are exactly the same design. This is the one in the GA mountains- it is about 400 feet away from the house. At the AL farm, it is a good bit farther away from the tiny house, down by the lower fields so we use the ATV or UTV to go back and forth
Tchess450
BX23S with 60inch deck. implements, blade, forks, spreader, and more.
Jun 18, 2018
45
Pa
Kubota in the detach garage, and the Deere out side. I bought a other house with a 3 car garage I will be keeping two bays for myself so more room for attachments. I will give the renters the other bay since I am nice person
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,456
639
Richmond, Virginia
Same, except I use the cheapo Harbor Freight 10 X 17. This is the third year. So far, so good. ROPS folded, it fits fine with the FEL on and the BH on. If the rear blade is on, the BH is outside and vice versa.
I have a few sheets of outdoor 3/4 plywood on the ground. They have also survived. I get the plywood free from a concrete guy that uses it once for forms then throws it away (gives it to me...) Rain water rushes under fine. The ground is somewhat pitched, the good thng is it it too steep to pool.
The negative is when it is dewy/wet out, the tractor gets wet(condensation) as well.
kd0wow
Neosho Missouri
I took delivery of a 14x32 prefabricated garage a week ago. My trusty B3350su moved 60 tons of base rock to make the level foundation. The door on the left is home for my Kubota and it’s little sister the Husqvarna riding mower and the door to the rights for the Harley
jryser
427
Plainfield
Prefab badass!!
Side R for the L3560
Side L for the trailer!
All kinds of extra space for implements!!!
twomany
B7200
Jul 10, 2017
793
139
Vermont
I've got one in the lower level of the barn/ shop.
One in the shop for "fitting work", for a front mount snow blower.
One under a simple shed roof off the shop, and the fourth is in "the tractor shed".
I really need to trim down. All these roofs are getting to be an issue!
goldenpsp
BX 23S
Nov 25, 2017
69
Baltimore MD
Sadly Mine is currently kept in the back yard. It was sort of a chicken and egg issue. I needed the tractor to re-landscape my back yard to build a new shed, but until it's done I throw a tarp over it.
afret
L3901, MX5800, U55-4
May 7, 2015
167
North Idaho
Tractor stored in separate garage.
Mini Ex in small pole barn since it's too tall to fit though the door of the garage.
bearbait
Dec 9, 2011
4,221
978
New Glasgow Canada
Mine has lived in a Shelter Logic right now for the past 4 or 5 years which I either have to recover this year or extend my garage. If only I had put 8ft doors in the garage when I built it.
PHPaul
Apr 2, 2015
1,281
1,594
Downeast Maine
www.eastovershoe.com
Run-in shed with a hayloft on top of it.
Old picture, everything shown is gone and replaced with the B2650 and a Pasquali.
3,058
Made a shed for the tractor due to the fact that I was too lazy to raise and lower the ROPS!
Shed was a beeeeaaauch to build too - front is about 3" off the ground and the rear is 9 FEET!
7,323
Mine does live in the attached garage. Not heated, but decent usually.
Since we burn wood pellets, one side of garage is taken up with pellets anyway. Keeps tractor near tools, power, etc.
ArkansasTed
2017 Kubota L3301 HST, LA525 FEL, 6' Land Pride box blade
Aug 5, 2017
Eureka Springs, AR
I keep mine in the attached garage at our other house. My wife and I still own two houses...married 10 years now. We live in the house that she was building when we met. My house (our other house which is underground) has a 2 car attached garage...plus I built a 3 car 30'x50' garage about 2 years ago at that house.
