I have a L2850 DT (4X4) which is leaking hydraulic fluid from one of the pistons that tilt the bucket. I have read that BlueDevil Hydraulic Stop Leak is a good solution to this problem. The leak is not real bad but has been happening for quite a while and is getting worse.
My problem is two fold. First, I cannot find the dipstick for the hydraulic tank.
Second, I see two possible filler holes for putting the stop leak and additional fluid in. I do not know which is the one I should use.
The first one is at the rear of tractor above the 3-point hitch mechanism. The second is under a cap in front of the seat and below the steering wheel.
Any help to clarify these two concerns will be greatly appreciated.
