Where is the hydraulic filter?
mleo
245dt
Aug 4, 2024
California
Hi,
I have a 245dt. The loader and 3 point lift hydraulics have been acting up. Weak, slow and occasionally non operating. I read the filter might need changing. Its and good place to start since it hasn't been changed as long as I have used it. I am not sure where it is. I took a couple photos of where I think it might be be. Are either right? There is a bonus question: What does the knob do?
5,175
Hi,
Have you considered purchasing a workshop manual?
mleo
245dt
Aug 4, 2024
California
Thanks for the help.I located it. It's a little dome with 2 bolts holding it in place.
2,150
This should be on the clutch side of tractor, low on the transmission and near the rear axle. It should look like a bump with two bolts holding it down.
There will be an o ring and a spring under the cover.
You may need to get the cover removed and grab the end of the filter with needle nose pliers to pull it out.
I just bought a new filter the first time I changed mine in my L185, since you have no idea what it’s condition will be.
Good Luck, and do drain the fluid first!
