Wheel Weights on The Cheap For BX Series ......
Li'l Orange Crush DpS
BX2380
Aug 26, 2023
10
Southeast Wis
...... So after looking at a bunch of threads ... not seeing what I thought would be "inexpensive " wheel weights ....and I didn't want cement or plastic coated weights ... and Buying New Cast Iron Wheel Weights is Soooooooo far outta budget ..... couldn't find any cheap wheel weights on e-bay or marketplace...
I started to ponder my options --- originally I thought of scavenging Front and Rear Brake Rotor and melting used lead..into them -- wheel weights, battery lead -- etc.etc... then I thought ----- why not use weight lifting "free-weight" disc's ?!?!?!.... hmmm ...
so I sourced two pieces of 1/4" x 10inch round plate -- either plasma cut or cut from round stock --- Amazon has weight lifting bars with an "ACME" thread (or some Chinesi-um dirivitive) -- for Cheap!! and they come with a "Lock-Nut" (so-to-speak)-- so -- after doing the calcs , bi-secting an "out-of-round 10inch disk ------here's my Adjustable Rear Wheel Weight Bracket ---- don't mind the "copper "colored paint --- I didn't have any black --
I source my 1 inch center hole "Free Weights" from FB Market place for cheap --- 160lbs were less than $100.00 (6-10lb weights and 4-25lbs weights -- 80lbs per side)
1 inch weight lifting Curling Bar From Amazon less than $25 (approx 52inches long -- all I needed was the threaded ends)
2 pieces 1/4" x 10" Diameter Steel Discs less than $40.00 cut
I cut the threaded part of the curling bar at 8.5inches from the end -- (2 pieces)
found absolute center of the out of round steel discs ( Google AI Helped with the calculations) and I drilled a 1.000 hole (bar diameter measured .969-ish 31/32" --?!?!?)
needed a bolt hole pattern of roughly 4@6.125-ish (again used Google AI for Calc) measured, drilled and tapped 4 holes for 7/16-14thread
I have wheel spaces on the rears so the bolts are 3inch .. (washer to inside of wheel) threaded them in the holes and used Nylocs on the Plate Side (kindda like a Double nut or Lock-Nut)
three 10lb weights per side fit Perfect inside the rim, and the 2- 25lb weights fit nicely past the "rim-lip" -- nice clean install
the Threaded shaft holds 80# per side -- with a 2 inch margin for adding two more 25lb weights or a single 45lb plate -----
please review the pics (kindda wish I would have taken pics along the entire build)
hope this Helps someone ....
Bearcatrp
Mar 28, 2023
952
600
Minnesota
Good job. Looks good. I got rid of my box for the back and sourced steel weights on CL. Now have 300 lbs on back of my 1880.
Shawn T. W
Dec 9, 2024
354
628
SW Missouri Ozarks
Looks good, but I'm curious on how you check the air pressure in them? Remove the 25 Lb weights?
I bought 2- 70 Lb steel weights and mounting hardware for my Massey Ferguson SCUT from my dealer for $277, just under $2 a pound ...
Bee-Positive
Nov 16, 2022
382
365
Amsterdam, NY
I used an old pair from a Craftsman lawn tractor my BX replaced, 50# each. Just had to buy longer threaded rod to reach. Sears still sells them for about $171 a pair new. Fit perfect and has a notch for the air valve.
Old Machinist
May 27, 2024
463
501
NE FL
Those look good. Free and cheap barbell weights are hard to beat.
I have a 120 lbs on a scraper bade and 300 lbs on my box blade. The only set I paid for was $40 and included the weight bench I sold for $30. I still have left over weights and bars and one bench laying around in the barn.
The two 100lb suitcase weights I got off CL for $50 for the pair. that adds a total of 500 or so lbs to my 500+ lb box blade.
