Wheel Specs B2150hst for Wheel Spacers
NorCalOrange
B2150HST, Brush Hog, FEL, Post Hole Digger
Mar 24, 2019
74
Newcastle, Ca.
Considering buying custom made rear wheel spacers for the B2150hst 4wd and need the wheel specs. Their is a shop that makes custom spacers for a lot less then the companies typically mentioned using the same materials.
I know the bolt spacing is 6 inches, 6 x 152.4mm. Where can I find the center bore size and stud thread pitch.
Also, do 2 inch wheel spacers make a significant, obvious, improvement in stability on steep terrain and hills? Or go with 3 inch spacers? My concern is increased bearing wear and axle stress with a wider spacer.
3,012
1,111
Your best bet if you are having custom spacers made would be to take measurements off your tractor and wheels so that they come out correctly.
Muzzy
B2650HSDC
Feb 13, 2019
274
WNY
2" Wheel Spacers will make a big difference in stability.
NorCalOrange
Mar 24, 2019
74
Newcastle, Ca.
Yes, Im thinking 2 inch would be good as this B2150 has the wider offset wheels and 12.4 x 16 tires making a 63" width.
These are B8200 specs that uses the same axle/hub assy as the B2150. Will verify on the tractor.
