wheel rusting around filler nozel
dgerwig
L2900, T1600
Jul 18, 2014
Round Hill VA
Gents
Just got my tractor 2 weeks ago and today I noticed this: Can this be welded or brazed to strengthen the area? Is it time for a tube? The rest of the L2900 is so immaculate (garage kept - 700 hrs) and since I've never had filled tires, I never thought to look for a problem here!
Cheers
David
Tooljunkie
May 13, 2014
4,150
Has a tube already, a slight leak and it starts rusting.
Disassemble, clean & weld up if necessary and repaint. You probably wont like what you see when you get in there.
6,600
Plan on replacing rim, the damage internally will be greater.
If it's already tubed then it will go years before you'll have any more of an issue then it being bad to look at.
