What's this doohickey called?
Shawn T. W
Dec 9, 2024
813
1,471
SW Missouri Ozarks
The door handle on my cabbed L5030 came loose yesterday, I took it apart and discovered it was broken inside ... I found a new outside handle https://www.messicks.com/parts/kubota/t0270-85102 but can't tell by the pictures if it includes what I need, I want to call them, but not sure what to ask ... Parts diagram doesn't show it listed separately.
I thought last night it was a "feral" (sp?) but now thinking it might be a "nut-sert"?
This one is loose ... I have both of the bolts that thread into these.
This one is missing and the housing is cracked ...
JasonW
868
583
Al
My first thought could be a rivet nut but probably not looking at the depth.
Im sure the nut experts will be here shortly
6,308
Looks like a pressed fit threaded insert. Odds are the plastic where it gets pressed into was fractured or broken either when it was pressed it or from a zillion uses( and nobody checked the retaining bolt for correct tightness ).
You could use the proper 'epoxy' to glue them back in, just be sure NOT to get any glue on the internal threads. Also, when installing the bolt, add a lock washer, check bolt every month or so.
Shawn T. W
Dec 9, 2024
813
1,471
SW Missouri Ozarks
Missing the second insert ... Just gonna buy a whole new handle ... I'll call and see it come with it installed?
Should in my opinion!
This is my temporary fix!
I'll be leaving out Friday morning again, so should have parts waiting when I get home next ...
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
3,278
2,977
Near Lancaster, PA, USA
The picture from Messicks sure looks like it comes as part of the handle assembly. It is likely either cast into the plastic or installed hot.
re54drider
L2800, FEL, Bush Hog
May 9, 2011
80
36
Goldston, nc
I have used those. Not designed to be repaired if it is installed with heat into plastic. Replace the assembly.
3,117
@Shawn T. W
The word you are trying to spell correctly is “ferrule”. “Feral” actually does apply since that describes something that is “in the wild state” like your missing part, but is usually used for domestic animals that are now wild. And the two words sound exactly the same.
Ferrules are generally not threaded but are smooth on the inside. Think about the metal things that are around the edges of tarps to tie them down, or the metal things you put in a loop of cable or rope to make the end loop stronger and easier to use.
What you are looking for is a press fit nut for plastic. I guess that ”threaded insert” is the generic term for them.
Like these:
I would be almost 100% positive that those would be installed in the part you purchased. You could purchase the insert and repair the existing part (as described above) but you might have trouble just buying one of the inserts. I believe that wood workers use similar things but they may not hold in plastic?
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,178
1,167
E.
we call the rivet serts (or rivet nut) if they get compressed to hold in place (squished out of round) or nut serts if not squished instead glued or formed in place.
BiggB
B7100D, B2030 front blade, Loftness 481E-TS
Mar 20, 2026
85
55
New York
That looks like just a knurled threaded insert you could try and glue it back up and if you have room to build up the area around it to help stabilize it I did a repair on a plastic panel with coffee grinds and superglue worked surprisingly well
Shawn T. W
Dec 9, 2024
813
1,471
SW Missouri Ozarks
Thank you, I just got a new outer handle assembly ordered, the nut insert does come molded into it ...
11,757
I added that right side handle (inner and outer) to the MX a couple of years ago. Definitely worth the cost at around $300.
11,757
It didn't come with it, or was it broken?
I'm guessing this is probably as good as time as any to add the window tint I have on that door ...
MX models have a steel plate on the right side door with no external access.
Shawn T. W
Dec 9, 2024
813
1,471
SW Missouri Ozarks
Oh, didn't know that ... Did it not have hinges either?
Just the outside part was $130 today
11,757
The door has hinges but Kubota elected not to provide an external door handle and only an internal handle so that you can exit if necessary. It's an easy fix but since an exterior and interior handle are are required it's a bit more expensive.
These are the parts I ordered for the upgrade:
010 COMP LOCK, DOOR COMP.LOCK DOOR RH
T0270-86010
070.1 ASSY HANDLE,OUTER. replaces #T0270-85100
T0270-85102
110 COVER COVER,DOOR LOCK RH
T0270-86150
120 KNOB KNOB,DOOR LOCK
T0270-85140
130 KNOB KNOB,INNER LOCK
T0270-85160
140 SCREW SCREW (2 each)
T0270-85130
150 ROD ROD,CY LINDER
T0270-85070
160 BOLT BOLT,SEMS
01023-50612
170 STRIKER, DOOR LO STRIKER, DOOR LOCK
T0270-85170
190 NUT NUT,DOOR STRIKER
T0270-70890
200 SCREW SCREW ,CSKH (2 each)
3F760-53430
210 W ASHER, TOOTHED, WASHER,TOOTH CONICAL (2 each)
04414-50080
11,144
Yes the door handle will come with the insert nuts.
They are part of the assembly
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,208
1,823
Pittsburgh
The missing piece is called a gizmatchi.
Shawn T. W
Dec 9, 2024
813
1,471
SW Missouri Ozarks
Yup, came today!
How's that for service on parts for a 21 year old tractor! Ordered yesterday at 10:21, arrived today at 12:48!
I couldn't see them in the pictures, as they are black, I was looking for silver like the one I had, shown in the center ...
Even included a new lock, which I never use ... Actually forgot and left the keys in the ignition last night, I usually bring them in ...
