What to purchase...
5,184
It’s a tractor not a child. They are made to be outside and used, not to be garage queens.
I keep none of my equipment outside.....ever!!!
Implements are always also inside,..... when not in use.
I take pride in keeping my equipment looking sharp!
80+ years ago my mother taught me to put my toys away at night.
I am still doing that!
I keep my cars in a garage too!
PaulL
B2601, MX5200.
Jul 17, 2017
2,781
1,778
NZ
Given the limited information I'm hearing:
- I want to mow, ~60 inch deck
- I want a snowblower, probably front mount
- I want to put it in my garage
- I'm upgrading from a Husqvarna
Therefore, I say BX2380 or B2601. LX is likely bigger than you need, they're really sized for a 72 inch deck. You're putting it in the garage so you can't have a cab.
Get the BX if you're mostly mowing and snowplowing, and not much else. Get the B if you want to run the loader a bit and have some rough territory you want to drive it in, or do driveway maintenance. They're about the same length/width, the B is quite a bit taller with bigger wheels and more ground clearance. If you want something that's a bit bigger than a ride-on, the BX is it. If you want something that's more of a tractor, the B is it.
You want to mow and a MMM is the right way to mow most of the time, so don't pay attention to those who say it's a pain to take the MMM off. It's not that bad, it's easier on a B than a BX, and the B comes with a drive over deck (that doesn't auto attach). The BX drive-over deck is more fiddly and it tries to auto attach. Rumour has it that the auto attach goes out of alignment and is then annoying, my BX never had drive over so I can't say that from personal experience.
Any of the Kubota models will meet your needs - BX, B, LX, even an L if you're OK with rear mower and rear snowblower. But the BX and B are really the right machines for someone stepping up from a ride-on.
ve9aa
Apr 11, 2021
1,193
972
NB, Canada
Terrible picture with not much frame of reference, but here's my TG1860 compared to a BX2380. The Husquarna is likely just slightly smaller than the TG1860 (if not almost the same size) My neighbour used to have one and I recall it being almost as large as the TG 1693670784653.png
