What Ply for UTV?
Tioga Tim
B2620
Nov 11, 2020
46
17
Upstate New York
I need new tires on my 1120. I have decided to go with a brand name I recognize - Carlisle. The tires I am considering are 6 ply. I use the vehicle around the yard, take it on the steep and muddy hill and into the woods, and also ride it on the country roads. I would not say I use it hard, as I have tractors. So - is 6 ply enough?
Carlisle Versa Trail ATR Trail.
Thanks,
Tim
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
2,936
2,334
Western MT
I think stock is 6 ply. My guess is 6 ply is probably fine.
I don't have a 1120 though.
MapleLeafFarmer
Lots incl. B and L kubotas
Dec 2, 2019
1,162
1,151
E.
not enough IMHO.
I think the unit weighs approx. 2,000# dry with payload of 1,500 for gross vehicle weight of 3,500 pounds.
Tires rated 720 pounds each so 4*720=2,880.
so good enough for light duty but under for rated duty.
plse check my math as I might be wrong but not enough tire if going to run at capacity.
6 ply to 6 ply might be same but my radar went up because Carlisle is a utility / recreational inexpensive sxs tire while the Kubota uses factory HD for work side by side that came stock with worksite tires. IMHO.
so I guess depends n how you intend to use it and how you intend to sell it (as a work unit or a recreational unit)
7,631
I've used 6 ply and then went to 8 ply on Ranger 700XP. No matter what tire I use the tread is fine but tire begins to leak where the tread meets the sidewall. The rubber cracks and gets a slow leak. Not under inflated either.
4,193
I LIVE in Mequite / Cactus / Thornbush country….and have a Kubota RTV and Kawasaki Mule…drive all over those thorny bushes around here willy-nilly….. . and their tires have “FlatOut” in them. NEVER have a flat. NEVER.
7,631
I LIVE in Mequite / Cactus / Thornbush country….and have a Kubota RTV and Kawasaki Mule…drive al over those thorny bushes around here willy-nilly….. . and their tires have “FlatOut” in them. NEVER have a flat. NEVER.
It is GOOD stuff.
