What kinda rims are these?
John T
2017 BX23S
May 5, 2017
741
196
under a rock
Is there a name for this type of wheel?
Obviously a 2 piece wheel
I don’t think its “split” unless the ring it on the inside ...?
Need to find a spare wheel ....
before I buy it
And drag it home
L35
Jun 13, 2010
423
247
CT
Commonly called open center rims.
BigG
Sep 14, 2018
1,949
765
West Central,FL
Re: Whaey will work t kinda rims are these?
Take you picture to the tire shop and ask them if they will work on it. My understanding is the tire themselves are hard to find and few people will work on them.
4,401
They are not split rims if they are mobile home axles (which it appears to be). Mobile home wheel are 14.5" tires. Made that way to keep folks for using them for continuous use on the highway. It's often cheaper to find a place that sells/delivers the homes and buy the tire and wheel mounted up.
The washers under the nuts are tapered to clamp on the wheel.
You can replace the entire hub with more common setup and different wheels and use a more common tire.
2,240
Yup, mobile home wheels. But there are at least two sizes. (diameter) I bought a newly built 500 gal water trailer before I got my well, and ordered a spare with it. Towing it home, I noticed the trailer had a list to one side, so I drove back to the builder. Turns out the guy who put the wheels on had grabbed three wheels from a stack the size of a small house, and got two different sizes. He swapped the spare wheel, and then I had two the same size on the ground. Spare was taller then, but I never needed it anyway, so I was fine with the mismatch.
John T
2017 BX23S
May 5, 2017
741
196
under a rock
Thanks for the info everyone.
Decided to pass on the treller.
What I really want is one of these
But Im too lazy to make it. LoL
Missed out on this one this morning...
Sux when you have to work for a livin
fast*st
M7040, L2900, F550 ford, Yanmar vio70 excavator, Case 580, JD 350 dozer, JD 644E
Jun 26, 2012
172
Northern Mass
While they are popular on mobile homes, the wheel is a Dayton style wheel, usually those are 10+ ply tires and can carry a huge amount of weight, thats why an entire house can have 4 small tires under it. They are also usually a 'half' sized tire, 16.5 etc which identified a non locking 15 degree bead seat angle. This allows you to swap a tire onto the wheel without much effort or a tire machine. Any commercial truck / trailer should be able to find tires as well as craigslist. I bought 4 for $20 each that came from a single use bridge mover, had 100 tires on it.
Most likely it was a mobile home axle and Dexter used to say they were built for limited use with looser tolerances on the bearings and such and brake components riveted in instead of bolted etc. But for a utility trailer they are a heavy duty axle.
John T
2017 BX23S
May 5, 2017
741
196
under a rock
Yes if you look close on the original wheel picture it does say Dexter.
