What is the basic difference?
5,559
I suggest going to www.kubota.com and browsing the different series.
Very basically, the differences are weight and frame size. All three COULD have the same horsepower; BX (23hp or 26), B (23 or 26), and L (25).
More weight means the tractor can more efficiently transfer horsepower to the ground, or lift better, both at the 3 point hitch (3PH), or front end loader (FEL).
A BX2670 will not be able to pull or lift what an L2501 can, even though the BX has similar horsepower.
Grandad4
Apr 5, 2016
336
90
Greensboro, NC
You may have noticed some of these models have similar engine horsepower, however that is only one of several factors going into a tractor's ability to accomplish work. The different models reflect varying sizes, weights and power levels. Choosing which model is best suited to one's needs is largely a function of what kind of work and how much of it needs to be done, and the acreage involved.
Spending even a few minutes at a well-stocked dealer's lot would give you a seat-of-the-pants impression of the differences that cannot be conveyed by simply reading the specifications.
ipz2222
L235, bx2670
May 30, 2009
1,927
32
38
chickamauga ga usa
It's like compareing a Ford ranger, an f150 and an f450. They are all ford trucks but each one is bigger, stronger, and heavier duty than the preceding one. You would'nt want to try to tow a 5'000 lb camper with a ranger and driveing an f450 back and forth to work in the city is too much truck.
winesalot
158
Chelan, WA
Perfect analogy. Thank you.
Missouribound
Jun 17, 2014
652
42
Missouri
Sorry for the rookie question but what is the basic difference between the BX, B, and L series machines?
If you are looking to purchase, what are your needs?
If you layout what you plan to do with it you may get buying advice.
If you are just asking to ask, great. Have fun here, there is a wealth of knowledge to be shared.:D
