KubotaHawg
L2800DT, LA463, Landpride ΒΒ1260, RCR1260, ZG222
Jan 9, 2022
86
109
NW Arkansas
It’s a county by county thing here. Many of the more heavily populated counties, Forsyth where we live being one of them, have blanket burn bans. Our place is a certified timber farm and also a certified agriculture district based on our use of the land. If I was performing a prescribed burn as a part of our forestry plan, I’m reasonably confident I could do that so long as I stuck to the specifications provided by the County Forester. We don’t have any prescribed burns in our forestry plan and I don’t think I could talk the forester into that for what is truly removal of yard waste, even though he’s been quite accommodating to our goals in the plan he constructed.
Large ag (what little of it remains in this county), landscapers, arborists, developers, loggers, etc. have to either chip/shred woody debris or haul to a landfill. Went from burning OK in county to burn with permit to no burning. I don’t believe burning pastures is acceptable here, but could be wrong about that. Haven’t seen anyone burn a pasture in many years. Used to be common practice.
Interesting—I imagine your situation has more to do with population density then, since forest mgmt in the south typically encourages prescribed burning.
Even though I live outside of Fayetteville metro area, Arkansas still has an overall fairly low population density. The USFS conducts large burns in the Ozark NF south of here every spring and it will smoke us out for about a day but that’s all.
Edit: I just looked up Forsyth county and that makes sense now, Winston Salem is a lot bigger than NWA cities.
Old_Paint
Dec 5, 2020
1,937
2,108
AL
I took the new dumper trailer out for a test run and went to collect firewood. The ground was extremely muddy, as you can see in the photos. I ran into several issues.
The area where my forest is located is quite tight, so I can’t make a loop to turn around — I have to reverse out. The tractor made deep tracks in the mud, and the trailer kept getting locked into those tracks. I couldn’t steer it sideways the way I needed while reversing; no matter what I did with the tractor, the trailer stayed trapped in the ruts. That’s when I got the idea to use a chain hoist — and it worked perfectly.
Then came the next problem. Since I had to use the winch, I detached the trailer from the tractor. That turned out to be a mistake. As I started loading the front part of the trailer, the screw that holds the support leg scraped along the leg, and the whole trailer tipped forward, as you can see in the images.
I had to unload everything, and even then it was too heavy to lift back into place without help — so I used the chain hoist again (very handy tool!) to pull the trailer and tractor together.
In the end, everything worked out.
It took me two trips to bring the whole tree home. The second trip was early this morning, when the ground was frozen — much smoother and easier compared to the muddy chaos yesterday.
One of these on the tongue would be your friend.
I took this photo when I was replacing the shackle bolts which were about 50 years old and a little worn.
I added one on both sides on the back end of the trailer so it wouldn't tilt back and lift the back of my truck when I drove the tractor up on the trailer. Despite the axles being so far back, the LX is still heavy enough to lift the rear of the truck. I learned this the hard way, of course. Fortunately, I was in this same spot and the truck only shifted sideways a tiny bit, but enough to teach me a lesson. It's only a 7K trailer, but enough to haul my LX. With these down and the tongue jack down, the trailer is basically sitting on a tri-pod. It ain't fun when you suddenly find yourself chasing your truck and trailer. I can easily remove them with a single pin and store them out of the weather when they're not needed, however, I find them exceptionally useful for raising and leveling the trailer. I don't think I've taken them off since I added them, except when I was at a big box store buying materials. They'd grow legs there quickly. So I just toss 'em in the back of the pickup since I have a contractor cap on it. Outta sight, outta mind.
With them down, I can even drive the LX up on the trailer without it being connected to my truck. Pretty much like just driving up on a platform when the trailer can't roll. The lower part of the leg is also telescopic with a pin (you can see it in the photo) which takes care of some handle winding and extends the range. Just make sure not to set it too low if you jack it up before loading it. The adjustable lengths are VERY handy when on unlevel ground.
When they're not holding the trailer up, I rotate them 90 degrees with the foot pad toward the rear and jack handle near the fenders. It was a game-changer for this trailer. IIRC, I paid about $50 for each of them. What I like most about them is that whether stowed horizontal, or in use vertically, they don't collect water inside with the jack handle on the side like that. If I know I'm not using the trailer for a while, I can raise it enough to take the weight off the tires which prevents them from flat spotting. When I first put them on, I felt a little silly and like I was trying to kill a housefly with a 20 pound sledgehammer. Sledgehammers work, though. Since then though, I've found way too many reasons to have them, and NONE to not have them. I can actually jack up one side of the trailer to change tires if I have to, without unloading the trailer. IIRC, they're rated 5 tons each, a lot more than the trailer will carry.
Very easy to install, especially if you can weld a little. Just weld the stumps on, and pin the jacks on. Easy peasy. They also have zerks for greasing the screw. Pretty impressive for cheap jacks, actually.
Not saying you did anything wrong (other than loading a disconnected trailer), but keeping that tongue off the ground is probably 90% of staying out of trouble with a trailer. What happened to you is exactly what prompted me to do this along with loading the tractor.
BTW, I like your little dumper. Is that the one Woodland Mills sells? It isn't highway rated and it's a little small for what I need (for a short while), but I really like the fold-down side panels. That's just as handy as a barn-door style tail gate.
7,077
Describe that implement on the back of your tractor.
River19
B2601, RB1560, BB1260 and BX2830 blower
Sep 10, 2020
337
567
NH/VT NEK
Winter prep done today ahead of 4-8" early this week.
Pulled the FEL, wrapped that up with the tarp, mounted the blower after greasing all the zerks on both the frame and blower before mounting. Grabbed the rear blade as well, I wanted to see if I could fit the full setup into the Morton this year with the camper sold and swapping that out for the smaller "fun car" that is now in the winter bubble on a tender etc.
Sure enough I can get the Ram 2500, the "fun car" and the full Kubota setup in. I also have my Carry-All frame in there that I use for my sand bucket as well, which I will put on my rolling dolly that usually holds my blower in the off-season.
The back up Honda blower was moved from shed to garage just in case.
Also prepped a couple fresh jugs of diesel and topped off the tank.
Dare I say I am ready for now........
Reactions: 11 users
Chanceywd
Mar 26, 2021
739
681
central ny
View attachment 166222 View attachment 166220 View attachment 166221 View attachment 166219 View attachment 166218 View attachment 166217 View attachment 166216
I am curious as to what your fun car is?
Mine is a 2006 Miata that is put up for the winter now too.
It is such a nice grocery getter , or dr appointments in the warm months, or a run for ice cream!
Bill
GrumpyFarmer
4,409
Has anybody ever tried to remove snow with the grass cutting deck (side discharge)?
Yes, I have with my Mid mount mowers. If it’s light snow and not more than a an inch or two, it does great. I assume it would be better than a handheld leaf blower, but if it’s wet or deep it doesn’t work so well.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,841
2,252
Near Lancaster, PA, USA
Keeping the cab nice and cool is more of a challenge on really hot days when the tractor is working hard out in the sun. A full tint would help, but I think insulation above the headliner would do the trick. I'll get to it eventually. In comparison, the M6060 cab is an ice box on hot days.
First of all, I enjoy pictures of your area every time you post them.
Although the cab temp was OK, I added foil bubble insulation inside the cab roof when I replaced the A/C expansion valve about 4 years ago. Home Depot or Lowes have it in rolls. A spray of 3M adhesive, some foil tape and a little time is all it took. Since the A/C worked well to start with, I can't quantify what the improvement may have been. The thermometer reading at the A/C outlet was 2 years before lining the roof with an outdoor temp of 89°
River19
Sep 10, 2020
337
567
NH/VT NEK
Bill
Ah.....I was looking at an NC or ND Miata for a bit as well, killer fun cars. In the bubble is a Porsche 911, a 997.1 C4S from 2006........there is some family history with that car and I am now the new custodian of it and enjoying the heck out of it. During the warmer months I was going on "therapy drives" after work when the mood strikes and a 20-40mile loop puts an amazing smile on my face.
9,709
Thanks for the photos and heads up on where to buy the materials and nice work! Very neat and tidy which is what I like. (y)
You mentioned in another thread how unwieldy the cap is so no doubt an extra pair of hands would help when removing and installing. I intend to do the same for the MX but currently don't feel a need to do the same for the M6060 since the a/c ducting isn't up above the headliner. However, if the MX isn't a terrible job I might get to the M at some point too.
