5,179
Welcome sir! Nice Orange!
Maine has lobster!
Montana has Rocky Mountain Oysters!
Your choice!
We have considered buying a summer retreat up that way. Previously we were considering Maine, but not sure how long my sister in law with MS is gonna make it long term living upp there with 6 months of winter.
GreX
BX2380
Jan 8, 2023
185
132
Maine
Must be a record breaking day for October 28th, 80* F here in southern Maine.
Opening day of deer season. The deer would spoil before dragging it out of the woods at this temperature.
So today I changed the oil & filter & fuel filter & greased her up.
Since putting a cab on the step loop seems a little tucked under the tractor when getting out. So took some aluminum angle and expanded steel and
made made a little extension so I'd have more to step on when existing.
I recorded 86°F on my front porch today, crazy.. and likely gonna see snow on Wednesday.
I "vacuumed" more leaves with the powered bagger, made short work of cleaning up the lawn again - BX also stayed in summer mode while I swapped to winter mode on the Ryobi riding mower.
BXHoosier
BX24
Jan 21, 2018
497
591
Indiana
Worked on the front yard again today. Had about 1/4” of rain early this morning so it was a little slippery on the surface but with more rain forecast for tonight thru Monday, I wanted to get some work done before it’s too wet. I found a concrete footer just below the surface from a previous flowerbed wall so I removed it. I used my 1964 Cub Cadet model 100 and homemade ripper to break up the dirt and small tree roots. I ran out of time so I didn’t get to move much dirt other than hauling off the pile I made yesterday when I peeled off the sod.
I also used the BX to haul a deceased groundhog down the fence row to release it back into the wild. It suffered from an unexpected and fatal case of lead poisoning. I’m assuming it’s the same one that took up residence under my deck last spring just before I started the deck overhaul and expansion. Hadn’t seen it since until yesterday.
Siesta Sundance
Oct 23, 2022
1,825
2,535
youtube.com
Maine has lobster!
Your choice!
Yes I know, we visit ME every so often. Last visited June 2023, but I have a house on the Tx gulf coast 2 hours away with endless blue crab to catch in an unique bay system with great fishing for reds, trout and flounder.
Trimley
BX23SLSB-R-1 plus additions
Jul 25, 2023
1,181
872
PNW-WA
Last mowing of the season was today. Wet wet WET. Tractor got washed, deck removed, cleaned and stored, FEL put on its new cart and all implements rolled out of the way.
Snow Plow and Box Blade installed. House and property ready for Winter. Bring on the snow baby!!
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,492
3,588
PEI Canada
Took the loader off for the first time. Probably was over thinking it so it took a whopping 3 minutes
It's going to the dealer for a recall campaign. Something to do with exhaust fumes getting in the cab. I never noticed fumes but it's getting done because I dont want to go for a dirt nap using it. I'll post a number for it when I see the paperwork. While it's there they are going to install the K-Connect and front blower.
Bearcatrp
Mar 28, 2023
946
590
Minnesota
Put gel additive in a few days ago. Today I fired it up and drove it around to slosh the fuel around in hopes some got into the fuel line. Tested one hand operation since shoulder surgery has me gimping it. Worked fairly well. Just takes a little more time to do things. Hoping snow holds off a month so i'll be a month into rehab to use my right arm.
pokey1416
Jun 24, 2020
567
843
SW Michigan
Took off the FEL and put a ball on drawbar so I can pull trailer full of kids on Halloween.
5,142
Couple of small jobs today that would have probably taken a good bit longer but for the Piranha toothbar and hydraulic top/tilt on the 3 point.
Leveled off a little spot for a ground blind. Started with the box scrape but it was hitting roots longways and just wanted to slide down them without digging in. The Pirahna sliced through the roots and dry clay like a cold knife through cold butter. Took some pressure but made a crisp, clean cut roots and all.
Toward the middle of the sewer line, which we mow a couple times a year and use as a de facto trail, we have this mildly irritating short stretch that’s maybe 60 or 70 feet long. You have to cross the slope sideways, which is no problem if it’s dry. If it’s wet, the Mule crab walks it in 4WD so best to hit that spot going about 20 to 25 mph so by the time you’ve slid halfway down the slope your past the steepest part. Only reasons to go through it with the tractor is to mow it, which would only be when sufficiently dry, or to recover a deer, in which case I’ll just crab the tractor through it same as the Mule, albeit a bit slower, and to heck with tearing up the hill. Bottom of the slope is a creek just past a briar patch and about 40’ strip of trees; top of the slope… maybe we’ll have a road up there someday but that’s a bigger long term project. Today it was dry as dust, I was there, the tractor was there with box scrape and loader, so I decided to take a flyer on flattening out a dirt path through the slopiest of the slope. Some dude working on the sewer tore the area all to pieces earlier this year sliding all over it with a CTL. I had already smoothed up that damage about a month ago but it was a bit too wet to do something this controlled then as there was a bit too much spinning and sliding in the wet.
Anyway, I’d never tried to use a box blade on an area covered in grass and weeds. Blade cut the grass nicely… for about 4’; at which point it plugged up with a ball of grass. I’m pretty dumb so I had to do that three times in a row before diverting to the Plan B I didn’t have. Disc harrow came to mind first, but that’s behind about 50 big heavy things in the shed and the Pirahna was riding around on the front of the tractor relaxing after it’s earlier 30 seconds in the spotlight. With one small exception attributable to operator error, was able to surgically shave off the grass/native fauna and relocate it to a nearby hole. Underlying clay was so hard, actually used the rippers for the first couple passes after the grass was gone. I’m reasonably confident I’ll be touching this up every few rains for a bit until it stabilizes. Will keep an eye on how/if it washes and may put a ditch on the uphill side if needed. But there’s also a decent chance I nicked a Sweet Gum root in there somewhere. If I did, I’ll have it stabilized by at least 4,572 tiny Sweet Gum saplings by lunchtime tomorrow.
Top/tilt earned its keep on this one, particularly tilt. Only had to adjust it about 24 times. But it was easy: just start the run with the tractor listing off to X degrees, tilt the blade until it looks level, proceed forward while keeping the blade level as the angle of the slope changes, flatten and raise slightly to disperse dirt toward the end of the pass. Repeat until it’s an acceptable pig path fit for a Kawasaki Mule and/or a small tractor. Turning a turnbuckle would have been a quite slow process (BTDT).
Had to cross both creeks to get to the sewer line, so cleaned up those crossings a little on the way by.
Reactions: 8 users
pokey1416
Jun 24, 2020
567
843
SW Michigan
Have you ever considered buying a grille guard?
Yes I've been putting it off, which is a mistake. I don't have a grapple but I do move wood with my forks.
S-G-R
Jun 17, 2020
1,492
3,588
PEI Canada
Headed to the dealer for a recall campaign and for K-Connect and front blower install.
Reactions: 7 users
John D 2
B2601 LA435 loader, 54inch MMM, carry all, boom pole, fertilizer spreader.
Jun 6, 2023
172
182
Not that I use it at night, but I decided to do the $20 upgrade to LED headlights.
Reactions: 8 users
S-G-R
Jun 17, 2020
1,492
3,588
PEI Canada
Too bad Kubota cheaped out on doing this themselves. I did mine a couple weeks ago and think they will be beneficial with the front blower.
