8,770
Finally had a worthy storm. The R14's amd 3310 worked well in wet, heavy packed snow.
Is that a snow pusher up front? Are you blowing snow out back? I'd love to have some snow like that rather than the 1/2" to 1" that we've been getting for the last few weeks. I really enjoy moving snow and it's been a few years since we've had a significant amount fall in a day here in the valley.
Mowbizz
Bx25d
Aug 19, 2021
548
311
One advantage of snow plow verse snow blower.
Slush, snow, ice and strong wind. Driveway was littered with down branches. From twigs to 4 inch diameter widow makers. Would have eaten up a lot of shear pins.
Just pushed them along with the snow and will pick them up in the spring.
Just like when you mow a lawn or field or whatever…when you blow snow you should have been aware of what is there that could cause trouble.
Usually, in my experience, there is a telltale branch sticking up (or an obvious large branch) in your path. You just have to get off and move the debris…no way I would trade a tactor mounted snowblower for a bucket or blade after having all of the above. The blower far outweighs the others for MOVING SNOW. Period.
JimDeL
Aug 31, 2022
356
401
Austintown, Ohio
Yep!
Started out this morning with the Toro blower. Made it about a hundred feet before it clogged up with slush.
Got the BX2380 out and used the FEL bucket to finish. With the UHMW edge on the bucket, just tilted it a bit and it was like using a squeegee on the asphalt surface.
johnjk
Apr 13, 2017
1,615
1,641
West Mansfield, OH
Went out and pushed slush from in front of the garage and barn. Darn blade keeps popping off the Pat’s quick hitch. Now that I have my implements on concrete and dollies, I’m gonna remove the Pats and go back to the standard 3pt. They work well in even ground but if you get that 3pt implement bouncing or flexing, it comes right out.
L35
Jun 13, 2010
582
516
CT
Have you guys with the plugged chute tried modding the impeller with the rubber belting like walk behind blower users? Supposedly makes a huge difference.
Mowbizz
Bx25d
Aug 19, 2021
548
311
Never heard of that one! What does the “mod” entail If I may ask?
my first thought is bolting rubber to the impeller blades? Can’t really see how that would improve slush performance.
JimDeL
Aug 31, 2022
356
401
Austintown, Ohio
The only snow blowers I've ever seen with rubber edged impellers have been single stage ones. The 'big boys' - double stage - use a second impeller to throw the snow.
Mowbizz
Bx25d
Aug 19, 2021
548
311
never owned a single stage blower (except for the SnoJoe I bought for the deck…) that has some type of rubber edge but again, never saw anything like this on a 2 stage.
S-G-R
LX3310 for now, L5460 in progress
Jun 17, 2020
1,325
3,027
PEI Canada
It's a pusher. HLA SP1500 60" this is my third winter with it. I have 64" Kubota blower for the three point.
L35
Jun 13, 2010
582
516
CT
If you google “snow blower impeller mod” a ton of hits will come back. It basically tightens up the space between the impeller and housing to throw the slush out instead of slowly letting it trickle out after building up in the drum. Here’s one of a wide selection of videos on it:
Lakeguy
LX2610
Jan 24, 2023
Manitoba
I just ran a 12 gauge primary wire with an in-line fuse (in loom) from the battery to the back rops on my LX. Wire tied it front to back along factory wire harness. At the back I'll have a abs project box to hold 2 switches and a small fuse box with 2- 5 amp fuses for my front and rear lights. Sure am glad my garage is heated. dropped down to -20. :LOL::LOL:
GrumpyFarmer
3,974
Something may not be set / adjusted correctly. It should have a bracket that slides over and sets in place for the link arms (sort of locks the vertical) and for the side to side there should have been some washers / keepers to prevent the pins in the implement from sliding out sideways. I don’t think it should bounce off.
ve9aa
Apr 11, 2021
1,193
969
NB, Canada
No pix, but snowblowed for 1.25hrs @ 5am just to be able to get out onto a road that was not plowed !
The BX is earnin' its keep.
johnjk
Apr 13, 2017
1,615
1,641
West Mansfield, OH
I have the lower arms quite snug. Only turnbuckles with my B3200. I do have the washers on the ends of the implement pins to keep them from sliding off. I may need to borrow my sons GoPro and see if I can’t capture some video of it popping out.
8,770
The good part about being married to an Aussie is the quick entry without having to go through immigration. She has dual citizenship, so leaves on her American passport, enters Oz on her Aussie passport, and reverses the process coming back home.
I have dual citizenship too, and going in on one passport and back on another isn't a problem, until it's a problem. ;) My brother lives in Mosman which is a suburb of Sydney. He's a professor at the University of Sydney.
Trustable
l2501HST
Jul 5, 2022
202
134
I have the same system on my l2501, and operate mainly in the woods with lots of dips, divots, mud, etc... and have not had this happen with a back blade and box blade. The first time I used the system I actually had my ballast (about 750lb concrete barrel) pop off and slide out on my driveway. I figured out I was putting the washers on incorrectly and that it why. It sounds like your issue is different though, their customer service is pretty good, they were really helpful when I had a question about the install. They seem to be a company who stands behind their product so hopefully they can get it fixed for ya.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
The only thing I would suggest is a bigger fuse block :) There is always a good reason to have a 12 volt circuit available back there.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,535
central ct
Another round of rain here yesterday. I was hoping to get to the grapple in the back yard but really need a few days of no rain :(
This is the project I need the grapple for - and maybe a bigger chainsaw. It may be a 'baby' saw but this battery powered Dewalt is doing fine. That is until I get into the thicker parts of the trunk :(
The base of both the big oaks is over 36" diameter
Trustable
l2501HST
Jul 5, 2022
202
134
Any saw is better than an axe!
