9,611
Nice job and being a fellow steel hoarder I am always saving any hole saw plugs for use too.
Thanks! I think I have a bit of a problem with hoarding steel. I have a hard time throwing out even the smallest piece.
Good luck on the well pump replacement. Are you going to use your tractor to pull the pump?
I have an "abandoned" well on my property that is 550 ft deep. The pump is still down there with all the wiring and I'd like to get it working again even if it's just a pump house sitting over the casing. A few summers ago, after being told by the previous homeowner that the well had dried up, I dropped a small stone down the casing and heard a splash. I dropped another while using a stopwatch to time the fall, and then calculated that the water level was around 250 ft down.
S-G-R
Grand L5460, X1100C RTV
Jun 17, 2020
1,526
3,717
PEI Canada
Took off the tiller and put the RFM on and mowed about 5 acres.
Chanceywd
Mar 26, 2021
731
675
central ny
Isn't it like 20' to the second drop? I recall something like that when I was pumping new wells at work we had for cooling. Did 4 of them and I used to lower 1-1/2 black plastic with a 2hp pump 200 ft. I rigged up a frame to go over the well with a pulley and a roller and would pull it with my ford ranger.
I still have that frame and a 16' "crane" I made for my 3pt on the 8N to raise the 32' trusses on my shop 20 years ago. I had a small winch on it and I was able to raise them by myself and the 12 high walls.
I made the "crane" from a damaged pallet rack end. I am thinking I can back that up to the well to start it and then manhandle the plastic . Maybe make a couple of clamp blocks of wood to hold the plastic to change the pull point too. Always trying to figure ways to do things and save the back. I plan on a brother or 2 to help when I do.
Bill
S-G-R
Jun 17, 2020
1,526
3,717
PEI Canada
Unloaded some trees off a 1 ton dump truck and put the phd on. I'll plant the smaller trees first and then switch to the 24" auger for the other three.
Reactions: 6 users
Old_Paint
Dec 5, 2020
1,929
2,094
AL
Sawburner
L2501, Gravely 526
Dec 18, 2022
NY
Oh my…That’s awesome. It looks like it would hold at least a fifth. (Doesn’t look like a Rehoboam) But would that hold a full handle? I have a small yard and really hate having to stop for a refill. That would be handy 😉.
I have lemon aid in it, any thing stronger I have when done. Full handle has me stumped 🤷‍♂️. It will hold about half gallon of beverage of your choice. I got it a couple years ago at a Loves truck stop they were selling them for coffee, now if I was to drink coffee ( don't like it), I would not get very far and would need to drain some off often.
MOOTS
MX6000
Jun 27, 2019
2,189
2,716
Canton, Georgia
A handle is common slang for 1.75L of likker.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
Bill
iirc the formula for distance dropped is D=16*T^2, where T is the time squared and D is the distance in feet.
so if it took 4 seconds to hear the splash the distance would be (4^2)*16= 256'
The formula use here is not exactly correct because sound travels at about 1125 ft/sec so a correction should be made. The splash would take about .2sec to hear. The distance would be closer to 230'
Magicman
Oct 8, 2019
6,057
9,528
Brookhaven, MS
knotholesawmill.com
The Post Oak will become 2" bridge decking and the Cherrybark Oak will be the "etc". It will become the railing around my newly rebuilt back porch.
I finished sawing those logs today so I will be back to bucking and skidding the remainder of the logs next week.
This last one completed my cut list for my porch railing.
The Cherrybark Oak is sawed and stickered and the Post Oak seen in the background is next.
The Post Oak turned out some beautiful lumber.
Ten 12' 2X12's which will be used for bridge decking at the farm.
Next week I will buck and skid the remaining three 12' logs and buck the limbs into firewood.
Reactions: 12 users
GrumpyFarmer
4,353
Wow. That’s a great great set up and project! ☕
9,611
I did a 3-1/2 hour cutting job yesterday and some of it was fairly intense. One of the areas to be cut had woody growth that was taller than the cab, but the MX and flail handled it well. The owner has some kind of SCAG zero-turn in the shop for repairs, but once he has it back he wants to be able to cut the areas that I handled for him.
You can see the swath that I cut getting into the old pig paddock in the fourth photo. The spring loaded clip that I used to hold the guard rod in place decided to leave the premises during this session, but fortunately I noticed and was able to find another clip. But now I remember why the rod is retained with a washer and cotter pin. :giggle: That tall woody stuff was challenging to cut, in part because the ground was so uneven with large dirt mounds all over the place. The flail did well but definitely took a beating.
So was this endeavor worth the $475 fee that I charged. Kind of, but not really. This was my first "commercial" job where some stranger pays me to do some work with a tractor. I cut my friend's place a few times each year and he's just a couple of miles away from this spot. He gives me some "pocket money" for cutting his field, but his place is easy to handle, it's fun, it's relaxing, but this is a different experience.
Reactions: 8 users
7,026
How many acres did you clear for him? My experience is when you do something that has been neglected charge a bit more then you think you should!!
9,611
I use the simple formula:
depth (ft) = 0.5 x acceleration due to gravity x time of fall in seconds squared
The error from the time it takes for the sound of the splash to get to the surface can be ignored since the speed of sound is much faster than the time it takes for the rock to hit water.
9,611
I really don't know ... maybe three or four. I was charging him an hourly rate and I know he was thrilled with the difference and was surprised that I went flat out for the duration. The problem with this sort of work is that people don't want to pay a fair price. Most seem to be stuck in the time when some neighborhood kid cut their lawn for $4 per hour and seem to think that $130/hour is ludicrous.
The other thing about doing this "one off" type of work is that you have no familiarity with the lay of land, what's hiding in the tall stuff, where the holes are, etc. Luckily the whole valley floor near the lake and river is rock free so there was little chance of hitting anything like that, but I found a couple of steel barrels, a plastic barrel, hoses and some other small crap hidden in the tall stuff. Rather stupidly I backed the flail into some areas with nothing more than hope. As someone said, hope is not a plan!!
The owner needed to spend more money to get the entire property sorted out and to go from this to this.
Reactions: 7 users
9,611
A couple more photos from yesterday's activities. There's a tall berm around the front and sides of the half of the property closest to the road which would be a pain to maintain with machinery. An excavator with a mulching head would be the way to go.
Siesta Sundance
Oct 23, 2022
1,832
2,544
youtube.com
I have always had high respect for those tractor operators that cut the sides of interstates and highway overpasses, some of those slopes are like 30*+ degrees of angle. Just incredible.
