Goz63
Kubota L2501, LA525 loader, QH15,Land Pride RCR1860, BB2560, SGC0660, forks
Jun 19, 2021
299
349
Mississippi
Ouch, tight to the fence.....
The bucket might have helped you get out. Thinking the grapple wasn't much help.
But again, tight to the fence.....
We've all been there!
I buried our old 'Moline as a teenager. Took a shortcut to our firewood cutting spot on our farm. I was way off our normal tractor trails. There was no bottom....
Dad was so mad. I don't remember anything for the rest of the day.....🤪
A few days later, a neighbor farmer hooked his IH 1486 to it....was all it wanted to do to pull it.
Yeah the bucket would have helped. The grapple was useless in this situation. Was able to get some timber under the pins to lift the front wheels and undo the vacuum from the mud. Got some timber under the front wheels then. Learned a lot lol.
PaulL
2,635
1,607
NZ
Getting stuck is half the fun. Getting out is the other half. No point having a tractor if you're not using it.
random
Nov 2, 2020
716
401
NC
Got the boards for my deck redo. Truck couldn't get down the road, so tractor to the rescue! It was painstaking (had to go really slow) but I managed to get the bundle of 16-foot boards set nicely by the deck.
Crash277
BX23S
Jan 17, 2021
844
621
For some reason the other pictures didn’t post.
Here is the end result. I also got about 900’ of cable buried today!!
Reactions: 6 users
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
Since my grapple is on its way (made it to NY then mysteriously back in Charlotte) I finished the hydraulic hoses from the fel to the rear remote. I have to congratulate myself on measuring - the hose length was perfect :)
Today I started the real work on the lawn. Used the box blade to spread 800lbs of limestone. That's 1/2 of it. The spreader I planned on using wouldn't work with the limestone :( Then I used the box blade to really rip the lawn up. Tomorrow I'll spread the other 800lbs and maybe get to use the tiller.
clarksvilleal
LX3310, LA535, BSS65 Box Blade, 6' Landscape Rake, Wallenstein BXM32 shredder
May 28, 2011
14
29
Maryland
Put a Top-n-Tilt kit from FitRite Hydraulics on the new LX3310. Looks great, works like a charm. (Yeah, I know -- gotta repaint that ugly iMatch Kubota gray. First on my list of winter projects.)
LX3310 Top-n-Tilt - 1.jpg LX3310 Top-n-Tilt - 4.jpg LX3310 Top-n-Tilt - 5.jpg LX3310 Top-n-Tilt - 7.jpg LX3310 Top-n-Tilt - 8.jpg LX3310 Top-n-Tilt - 10.jpg
Reactions: 7 users
Crash277
BX23S
Jan 17, 2021
844
621
That’s a neat contraption you have there
Thanks! I get credit for building this one out of stuff I had laying around but I got inspiration from a ton of different post on here and some YouTube videos. Here’s a better picture. If I ever use it again I will hose clamp the pipe to the scarificer. A few times I had to hop off, bend it closer and then back up and go again. Because it would bend away from the cutting edge and the cable wouldn’t go into the little trench. I also bent the top of the pipe on a better angle for the wire to feed in as it was rubbing on the coating a bit.
7,075
Changed battery. No issues with old one.
After 8.5 years, don’t want it to give up in January when I need to move a foot of snow.
Ikc1990
Kubota m125x, m9000, b2710, and other equiptment
Dec 2, 2020
292
130
Vermont
This was yesterday. Cut loaded and delivered 2 loads to sawmill at one amish farm couple towns over. He only charges 15cents a board foot for milling. So hoping 2 or 3 loads tomorrow. Cant afford the lumber for what crap they are selling at hardware stores these days. And have a few projects to get done so cutting more trees to thin out crap so we can add more taps on sugar bush. So dual goal accomplish in progress lol the homade manure forks we use to clean barn and old hay from round bale feeders, were awesome for loading logs, moving brush. Best couple hundred bucks spent! Huge thank you to Awsome welding in Charleston vt for makeing my idea work. Hes working on a 3pt hitch bale spear with slide on balast box now. Then 1 more prodject be4 winter for him. Lol. Between full time job and farm it's best to hire something's out for me.
ctfjr
L3800HST
Dec 7, 2009
1,982
2,538
central ct
My next chapter in the new lawn saga. As mentioned I spread 800lbs of limestone yesterday and ripped the lawn up pretty well with the box blade. Today I removed a ton of harvested stones from all that ripping as well as several good sized roots. Note to self, 80' oaks have large roots.
The plan was to spread the other 800lbs today and remove all the roots that are sticking up. If I can't rip them up then I'll just cut them out.
Of course my wife had another idea. . . Several years ago I made a berm about 70' long and 4' high right at the edge of the lawn / woods. I planted a variety of flowering plants. The deer thanked me for my generosity and ate them. After replacing them a couple of times I finally gave up. Deer 1, Jerry 0.
The berm just became a pile of dirt covered in weeds. My wife wanted it out. As my #3 son suggested, better do it now or rip up the new lawn later. So this morning I demolished the berm with the loader and box blade. It took about 2 hours. This is the 'after' pic with where the berm was marked in.
I thought I could finish the lime spreading this afternoon and till everything tomorrow. Then the rain came :( Now I'm stuck and will have to wait till everything dries out. The one plus is the lime will get a good start dissolving.
D
Deleted member 47704
Guest
Was going to put the BXpanded piranha bar on today and add another grab hook and clevis mount , but its raining.
Magicman
Oct 8, 2019
6,057
9,535
Brookhaven, MS
knotholesawmill.com
This is a continuation from Reply #9564 back on Page #479. Wow how time flies.
Both of the gearboxes were replaced on my Bushhog 3008, shown here before the input shaft were connected.
Looking good underneath.
@$500 each I did not replace the stumpjumpers but it did get new blades.
So now my Bushhog is happily back on the farm and hooked up to the M4900. Actually I too am happy. ;)
Mak65
L2501 HST
Apr 25, 2019
135
112
TX
Responding to Old Paint in post #9742 - yes, bent the blade on my shredder. Managed to get back up and put PB Blaster on the nuts but didn’t get to replace the blades. I did get a picture if I can get it to post
sardillim
b2650
Nov 24, 2019
128
66
Easton
Removed the interior, and dynamatted the inside of the cab, also added a new audio receiver , front speakers , sub woofer and new rear speakers
Reactions: 7 users
Crash277
BX23S
Jan 17, 2021
844
621
No picture cause it wasn’t fun. Dug a grave today for a neighbors pet goat. It fell off a platform when it was sleeping and broke its neck.
  • Sad
7,075
Awww, that stinks…..goats can be real characters. Neighbors had a few I took care of sometimes.
D
Guest
Put on Boltonhooks grab hook clevis eye combo and tooth bar. Ripped out a few more trees.
